Old 03-09-2023, 02:47 PM
highway star's Avatar
highway star highway star is offline
Default Sealing valve covers
Just a tip, on the oem W72 chrome valve covers, the bolt holes deform from over tightening. So when I was replacing the gaskets, decided to flatten them out using 2 hold down tabs & a dead blow hammer on the edge of the workbench. Here’s before & after pics:
ID:	608605   Click image for larger version
ID:	608606   Click image for larger version
The Following 2 Users Say Thank You to highway star For This Useful Post:
Old 03-09-2023, 04:09 PM
Stuart's Avatar
Stuart Stuart is offline
It can happen to pretty much any stamped steel valve covers, if previous owners were ham handed. In extreme cases the valve cover can actually crack around the bolt pad. I have a pair of them out in the garage like that.
Old 03-09-2023, 09:57 PM
Trevor78 Trevor78 is offline
And of course, the typical response to a small gasket weep is to give them bolts another tweak tighter, and so it goes.
Old 03-16-2023, 07:22 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
I just flattened mine by pressing them in a table vice with rags on each side to prevent marring. Then I installed load spreaders. Not a drop since.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
