Old 05-08-2012, 12:26 PM
67bluegto 67bluegto is offline
Angry 69 Judge Driver's Door
Last year while at Cruisin The Coast my driver's door; for some reason, would not open. Twl of my friend's wprked on it for a couple of hours and finally got the door to open. Since then, I did not have an event like that until this past Saturday. The exact same thing happened.
That door acts like the locking lever in the ilocked position. Has anyone had this happen to them?????? Anyone ever had this happen to them? If so, what did you do to fix this situation???
Old 05-08-2012, 12:48 PM
marxjunk marxjunk is offline
take it to a professional before ya have a real problem..acts like the latch mechanism is wore out...
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 05-08-2012, 12:58 PM
dr-doug's Avatar
dr-doug dr-doug is offline
Put it this way, I started to type another response and gave up. It could be a bunch of different things, maybe several combined. I hate texting, and typing is a strong second.
Your problem is no more than a two hour fix given you have the three potential replacement parts on hand. 100.00 plus parts here in good old Quincy,Illinois
Doug
71 SILVER AUTO JUDGE
70 RED AUTO III JUDGE
70 GOLD AUTO III JUDGE
70 SPECIAL ORDER SABLE BLACK 4SPEED III JUDGE
70 ATOLE BLUE AUTO GTO
69 C.RED 4SPEED III JUDGE
67 WHITE 4SPEED 400 VERT FIREBIRD
65 MAIZE 4SPEED TRIPOWER VERT GTO
65 TURQ. 4SPEED TRIPOWER VERT GTO
WANTING A IV......
20 other non-pontiacs which need to be thinned down so I can buy more PONTIACS
Old 05-08-2012, 01:24 PM
quicksilver97ta's Avatar
So I you couldn’t open it from the inside either? That would eliminate the outside handle being the problem. Remove door panel and inspect. You probably just need to remove, clean, and and re-lube the door latch/catch mechanism it.
Old 05-08-2012, 01:35 PM
Next time it does it try locking and when you unlock the door push the outside handle in and release it before pulling up on the lock.
I've got a truck this happens to. It's not bad enough to replace the latch yet but it is annoying.
Mike
former." --Albert Einstein
- Winston Churchill
Old 05-08-2012, 01:37 PM
dr-doug's Avatar
If the hinge pins are not worn out, and the door is perfectly aligned, quick is right...Probably just the latch, try a good dose of PB blaster then a little white lithium greese first without even disassembly. Tooth brush and q-tips to clean what you see.
Doug
WANTING A IV......
Old 05-19-2012, 07:58 PM
Bluesugar Bluesugar is offline
when the 2 nylon guides that track your pull up rod wear out the rod just flops around and can come out of its guide to the latch...I've seen these for sale in the Year One catalog
