66 big Pontiac accessory question
Has anybody made a bracket or can they show where they've taken out the power steering pump and relocated the alternator down low on a 1966 full size car.
I'm going to start chief executive I'm wanting to put a roots blower on. And I'm thinking it might be easiest to get rid of the power steering and alternator bracket assembly and just relocate the alternator down lower to make room for the blower belt. I would also be looking at converting from power steering to a manual steering box. Does somebody make a steering box that can be mounted on the car with a better turning ratio so you can still steer a little easier without power steering? |
I think this is going to look cool once it's all done.
If your Alt is up on the drivers side of the motor like my 70, I had no problem with mine and my ps staying right where they where stock.
While the Alt is not in this photo you can see how far the drive is away from where these items mount.
I do stuff for reasons. |
The Following 2 Users Say Thank You to 25stevem For This Useful Post: | ||
It looks like the belts would get in the way
Your drive pully sits much further back towards the case snout then mine does.
Is your pully 3" wide, or two inch?
You need to figure out what belt drive will work for you versus trying to build the rest of the car around existing parts. Case in point, snouts come in different lengths. And case sizes matter too. What works for a 6-71 SBC won't necessarily work on yours. I'd start by mocking things up, and I'm not talking about setting it on the hood. Do you have a Pontiac blower intake already? First thing you might look for is distributor clearance. Changing the front plate/snout seems almost like a foregone conclusion.
The floor hasn't been converted yet that's just a random pulley I had sitting in front of the blower it's not even connected it's just sitting here lol
I would buy a kit, all that stuff is figured out.
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
