Old 12-04-2022, 07:27 AM
mysticmissle's Avatar
Default 1972 SR 455 block 2 bolt standard bore
Bringing to machine shop this week to be cleaned and magged will be available after that, unless you want to do the leg work, and take it before i get to shop
485428 block is cast D052, SR888xxx i will confirm # if it matters. No vin stamp or letter code. It is a a 2 bolt block only drilled for two bolt mains. Removed from a 1970 Bonneville.
It definitely needs a bore. It should clean up at 030. I have a couple sets of trws on stock rods if you are interested
$2200 for block cleaned and magged. Will help shipper if you are not local to RI
try and get pics up
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 12-05-2022, 06:50 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Would you mind posting pics of the cast date, casting number, SR number, and main caps? I’d love to add your SR block to my data base.
Old 12-05-2022, 08:27 AM
It is SR 88872 i will update pics when i get it back. How large is your database of SR stuff?
1964 540 gto
Old 12-06-2022, 12:32 PM
Thanks!
I’ll have to check, but it probably close to 100 units.
Old 01-25-2023, 04:30 PM
shop just called, block is in excellent condition and will clean up w 030 bore pistons.. its is now cleaned and magged. in addition i have a set of 4 bolt main caps for this block available. Price with 4 bolt caps but not machined for them is $2400. i can get them installed and line honed with deposit. also can have them do the bore with a deck plate before i take it home.
will consider trades up or down. i will get pics in next week or two
1964 540 gto
Old 02-24-2023, 03:03 PM
Pics, block has been magged and pressure tested it blasted, will clean at 4.181 currently standard bore w a ridge. Will trade parts up Or down to lessen cost will
Pallet and help a shipper lmk
ID:	607814   Click image for larger version
ID:	607815   Click image for larger version
ID:	607816   Click image for larger version
ID:	607817   Click image for larger version
1964 540 gto
Old 02-24-2023, 03:05 PM
More
ID:	607819   Click image for larger version
ID:	607820   Click image for larger version
ID:	607821   Click image for larger version
ID:	607822   Click image for larger version
1964 540 gto
Old 02-27-2023, 09:56 AM
$2000 with caps, 1600 wo 4 bolt caps
1964 540 gto
