Old 12-04-2022, 09:47 AM
luvagoat luvagoat is offline
Default clutch pedal return spring
1967 GTO
My Z bar does not have a hole for the return spring. I've ordered the spring but I don't know where to drill the hole in the Z bar and where does it hook to on the frame? Pictures would help, thank you
Old 12-04-2022, 07:49 PM
Jeff Hamlin's Avatar
This is off my '66 but basically the same...
Name:	CLUTCH LINKAGE 66.jpg
ID:	603047   Click image for larger version
ID:	603048   Click image for larger version
ID:	603049   Click image for larger version
ID:	603050   Click image for larger version
Old 12-06-2022, 06:17 PM
6d7gto 6d7gto is offline
Here's a 1967 off the car, showing the holes in the Z bar.
The small spring goes to the clutch fork holding it in place with the adjusting rod/swivel mechanism. The large spring goes to a hole 'punched' into the firewall (torque box) as pictured in Jeff's photo. I say punched because it doesn't seem to be drilled from the factory. I will try to get a photo of the torque box hole if needed.
ID:	603168   Click image for larger version
ID:	603169   Click image for larger version
Old 12-07-2022, 07:25 AM
Larger View of image above;
Old 12-07-2022, 08:29 AM
Great photos, Thanks
How far up the arm from the shaft is the hole? Looks to be about 2" is that correct?
Old 12-07-2022, 11:39 AM
No, it is exactly 4" (on center) from the center of the large clutch rod hole to the center of the return spring hole.
