Old 10-27-2022, 06:44 PM
cnc's Avatar
cnc cnc is offline
Default Reglue dash Pad edge
So 1973 Firebird and the dash is in very nice shape no cracks etc....
Only concern is the lip area that sits against the metal frame of the car is curling in spots but is still quite pliable...anyone reglue sections and if successful what did ya use...Chris
ID:	601221   Click image for larger version
ID:	601227   Click image for larger version
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 10-28-2022, 11:39 AM
I had this issue with my 75 Camaro. If I remember right (18 years ago), I used a construction adhesive and layed bricks on top to keep compressed while it cured. It stayed until this day.
Old 10-28-2022, 06:25 PM
cnc's Avatar
cnc cnc is offline
Hmmm construction adhesive was also looking at contact cement
Old 10-30-2022, 07:58 PM
cnc's Avatar
cnc cnc is offline
Went and got some construction adhesive some popsicle sticks and glued it with Couple clamps with light pressure....gonna let it sit overnite and see how it looks tomorrow did a small area at first .
Old 11-07-2022, 10:30 PM
cnc's Avatar
cnc cnc is offline
Think it turned out pretty decent…also painted it….
The Following User Says Thank You to cnc For This Useful Post:
Old 11-07-2022, 10:47 PM
Looks good. Nice it worked out for you.
Old 11-08-2022, 12:03 PM
Keith Seymore's Avatar
Construction adhesive: like "Liquid Nails"?
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
The Following User Says Thank You to Keith Seymore For This Useful Post:
Old 11-08-2022, 02:44 PM
Shiny Shiny is offline
You should be happy with that! Looks great. Glad the adhesive worked.
Old 11-08-2022, 09:00 PM
cnc's Avatar
cnc cnc is offline
K
I’d have to go double check but think I bought this stuff applied it with popsicle stick small ones then used larger pop sticks to protect the dash when the clamps were applied…
https://www.homedepot.ca/product/lep...-ml/1000706486
Old 11-08-2022, 09:03 PM
cnc's Avatar
cnc cnc is offline
Yeah I’m very happy how it turned out
