Old 11-03-2022, 12:31 AM
cadtech cadtech is offline
Default Stiff Suspension?
Today I mounted tires and rims on my restored 67 GTO frame to roll it out of the way. After I set it down I could not get any travel out of the front suspension. I do not have any control arm bushings or sway bars tight yet. Is it possible I need the weight of the engine, drivetrain, and body to see movement? I thought a 225 lb man bouncing on the front end would get some kind of travel.
Old 11-04-2022, 05:57 AM
Jeff Hamlin's Avatar
Thumbs up
Yea it's going to need a bit more than that.
Even with the engine in place, it takes a little time to settle down
Name:	BOBs 66  CHASSIS 1.jpg
ID:	601688   Click image for larger version
Name:	BOBs 66  CHASSIS 2.jpg
Old 11-04-2022, 07:21 AM
dataway's Avatar
dataway dataway is offline
Mine was the same way, and I had the same thoughts, after you hang 2000 lbs on the frame it behaves fine.
Old 11-06-2022, 04:17 PM
geeteeohguy's Avatar
You need the car together with the body, engine, and transmission in place and it sitting on the wheels before you can tighten the A-arms to avoid bushing damage.
Jeff
