Old 11-21-2022, 02:47 PM
GoreMaker GoreMaker is offline
Default Clearance issue between cam bolt and timing cover
I bought a cam bolt and washer from Precision Automotive a few months ago. Last month I installed it, confirmed that I had 0.006" of end play on the cam (it's a torrington bearing setup from BOP Engineering), and then shortly after that I installed the timing cover using a paper gasket and ultra blue RTV (because that's all I had on hand). Today I decided to re-seal it because the blue RTV bugged me and I finally had some black on hand. When I removed the timing cover, I noticed some aluminum shavings on the cam timing gear. So I checked the inside of the timing cover and found this:
I'm not sure what the issue is. It could be the cam bolt head being too tall, or the washer being too thick, or the timing cover being too shallow (I really doubt this last one). This is what the bolt and washer look like, fully torqued with the eccentric sitting flush on the timing gear and the tang engaged in its slot:
Anybody know what might be wrong here? I'm really glad I found this before trying to run the engine. There was no indication of any issue when I tried turning the engine over by hand.
Old 11-21-2022, 03:30 PM
Verdoro 68's Avatar
The stock cam bolt and washer sit below the fuel pump eccentric, so it looks like the bolt/washer combo you are using is too tall and rubbing against the timing cover.
I have a Simms torrington setup on my engine too, but it didn't come with that bolt/washer setup.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 11-21-2022, 03:37 PM
My timing set didn't come with a cam bolt or washer at all, those were purchased from a different source. I just checked the bolt/washer that I got from Butler, and the head of the bolt is MUCH shorter. Doesn't stick out past the eccentric at all. However the bolt is overall much shorter as well with maybe half as many threads going into the cam. The washer for both is the same thickness.
I'm thinking the head of the bolt provided by Precision Auto is just way too tall. I'll use the Butler bolt instead and hope there's enough threads. Luckily that bolt only gets tightened to 45 ft-lb anyways
Old 11-21-2022, 03:53 PM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
The stock washer is flat if using the fuel pump eccentric. There is an aftermarket washer that has a recess for the cam nose when you do not use the fuel pump eccentric. To me it looks like bolt head goes in a recess?
Skip Fix
The Following 2 Users Say Thank You to Skip Fix For This Useful Post:
Old 11-21-2022, 03:57 PM
Originally Posted by Skip Fix View Post
The stock washer is flat if using the fuel pump eccentric. There is an aftermarket washer that has a recess for the cam nose when you do not use the fuel pump eccentric. Tome it looks like bolt head goes in a recess?
Yes, but taking into account the recess, the washer I got from Precision Auto has the same stacking height as the flat washer from Butler. The head of either bolt fits inside the recess. The washer definitely doesn't contribute to the extra height. It's all in the bolt head
Old 11-21-2022, 04:01 PM
Verdoro 68's Avatar
Good catch - it looks like that washer setup is for when the eccentric isn't used.
https://butlerperformance.com/i-3164...fuel-pump.html
Ken
Old 11-21-2022, 04:12 PM
johnta1 johnta1 is online now
If bolt is longer might check depth of cam hole and make sure bolt isn't bottoming?
Otherwise try grinding the bolt head down and see if you can still get a socket on it?
Old 11-21-2022, 04:36 PM
You're right, the bolt is in fact intended for applications where the eccentric is eliminated. That's why the washer is so wide and has a recess. The washer itself isn't causing any issues though, and I definitely like it better than the standard one. It all seems to be working fine with the standard grade 8 bolt that I got from Butler, so all is well now.
Old 11-21-2022, 04:41 PM
Skip Fix's Avatar
If you use it without the eccentric you flip it over. I have 2 motors with those because I am using an electric feul pump on them.
Skip Fix
Old 11-21-2022, 04:47 PM
Oh I see, so it goes over the cam snout much like the eccentric currently does. Live and learn!
Old 11-21-2022, 05:45 PM
25stevem's Avatar
25stevem 25stevem is offline
I am glad you had to take it apart, because there does not look to be drop 1 of oil, on the timing chain, nor in the rollers which is even worse!
Am I correct in the way I am seeing that?
If so that chain needs to be removed and soaked in oil.
I do stuff for reasons.
The Following User Says Thank You to 25stevem For This Useful Post:
Old 11-21-2022, 05:50 PM
It soaked in automatic transmission fluid overnight after I cleaned it in an ultrasonic parts washer, then it was coated in motor oil. It's as fully impregnated as it could possibly be. Just doesn't show up in pictures, I guess
Old 12-06-2022, 11:14 AM
peters23 peters23 is offline
Maybe a dumb question, but why would you *not* install the eccentric. I would think if you someday decide to go back to a mechanical pump that would make the changeover a lot easier.
The Following 2 Users Say Thank You to peters23 For This Useful Post:
Old 12-06-2022, 11:17 AM
That's a really good point. I doubt the eccentric causes any kind of significant imbalance, especially since the cam turns at half speed. I have no idea why anyone would eliminate the eccentric, even if they don't plan to use it, unless they just didn't have one on hand
Old 12-06-2022, 11:21 AM
Incidentally, it's worth mentioning that Precision Automotive never replied to my email about this. Even if the issue was caused by my own misunderstanding, a reply would've been appropriate. I was willing to understand a late reply due to my email being sent shortly before Thanksgiving, but it's been over 3 weeks now. I'm not impressed.
Old 12-06-2022, 11:29 AM
mgarblik mgarblik is offline
Some people like the "solid" attachment of the "Butler washer/cup" vs the factory set-up if they are not going to run a mechanical pump. The factory set-up can cause a light rattle noise without the fuel pump arm preload riding on the outer cup. Generally, not a deal breaker either way.
Old 12-06-2022, 11:47 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is online now
This is why I support, and purchase, buy from those who take the time to support the end user. You can always find it quicker or cheaper but there is a reason they maybe. I too would have expected at least an explanation or a you screwed up email.
Jim
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 12-06-2022, 01:53 PM
Skip Fix's Avatar
This!. I have one on my latest 455 in case I run a mechanical. 400 in the 81 is stockish so a mechanical but all my others use an electric pump.
Skip Fix
