clutch pedal return spring
1967 GTO
My Z bar does not have a hole for the return spring. I've ordered the spring but I don't know where to drill the hole in the Z bar and where does it hook to on the frame? Pictures would help, thank you |
This is off my '66 but basically the same...
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Here's a 1967 off the car, showing the holes in the Z bar.
The small spring goes to the clutch fork holding it in place with the adjusting rod/swivel mechanism. The large spring goes to a hole 'punched' into the firewall (torque box) as pictured in Jeff's photo. I say punched because it doesn't seem to be drilled from the factory. I will try to get a photo of the torque box hole if needed. |
Larger View of image above;
Great photos, Thanks
How far up the arm from the shaft is the hole? Looks to be about 2" is that correct? |
No, it is exactly 4" (on center) from the center of the large clutch rod hole to the center of the return spring hole.
