It is a loss of vacuum signal to the carb when the secondary blades open suddenly that causes the stumble.
We only had a "stumble" during our testing when the air cleaner lid, stock or the X-Treme lid was too close to the carburetor. If no lid was used at all, there was no stumble....Cliff
Another air cleaner base incident Cliff helped me clear up was the vent tube(7044266). Someone had cut the vent tube down to clear the bottom of the air cleaner and had a screen in it, the car had a stumble. Cliff recommended to put a new vent tube cover on and drill a hole in the air cleaner base as it should be, and it helped the stumble.. Amazing how something that small can change how the carb works..
David Jones
Which drop base air cleaner are you using? |
1.5" aluminum. 4" filter.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Which Brand / Model?
Thanks |
I've been away from here awhile, and HTML doesn't seem to work, and I can't get these pics to upload
Anyway, I recently dyno tested three different aircleaner bottom plates. I used the same filter element and top housing on all three tests. Same car, same gas, same dyno, all tested within a reasonable time of each other. One pic of bases at http://i235.photobucket.com/albums/e...xzrewq/073.jpg Another http://i235.photobucket.com/albums/e...xzrewq/074.jpg And results http://i235.photobucket.com/albums/e...q/SCAN0001.jpg IMHO, you'd be better off with a flat base and no spacer. Lee Atkinson
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
Greg Reid Palmetto, Georgia |
Greg,
The "Flat" is the blue one. It is steel, and I took it off a little 302 Ford years ago. It was just laying around, and I tested it for giggles. I was REALLY shocked when it made the best power! It has the rounded "berm" between the filter and carb opening, but it is effectively zero-drop/zero-rise. The "black" base is the "Medium drop" and is actually chromed, it just is a little darker than normal. It is ~1" drop. The rounded aluminum is the big drop, and I measure it at ~1.5" drop. Ironically, I also *thought* this one would be a great performer, and is the unit I used to make my air cleaner assembly! I've got alot of time and money invested in my current assembly, and now need to give serious thought on whether or not to change it all out.... Additionally, on the same car/motor, on the same day, I found ZERO performance when using a 4" tall K&N over a 3" K&N.
Did you dyno the 4" or 3" filter with the big drop base?
What shape was the lid?
DaveD, I bought off of Ebay a year or so ago from a "dirt track racing" equipment supplier. It was a no number, in a plastic bag kinda thing. I bought it because I liked the shape and wanted to run a 4" filter.
David, I tested all 3 with the nicely domed lid that cam with the rounded base. All 3 were tested with a 3" K&N that is virtually brand new. I did not test the rounded base (1.5" drop) with both height elements, but I did test the medium-drop (1") with both the 3 and 4 with the rounded top, and they performed virtually identically. Lee
If I may.... Can a 4" filter be used with a flat bottom in a 68 GTO ? I am running a 1" drop (maybe...?) and a 1" spacer with 2" filter. Or can I use a 4" With current set up and I am running a RPM.
Didn't know that significance of using 4" to 2"... Thank you.
Send it! It’s going home on a trailer. |
So the 3" filter was effectively a 1.5/2" filter with the 1.5" drop base? I'm not trying to argumentative, but wonder if those recommending a flat base are comparing apples to apples.
I just went back through my notes. This illustrates the importance of taking good notes on such a project!
Now, I had 3 different bases (plus a second 1.5" drop rounded-base bottom that is now attached to the bonnet that seals to the hoodscoop), and actually 5 different filter elements that I tested. I had some different lids, but ran out of time and enthusiasm before I could test those. In reviewing my notes, I see that I actually did NOT test the 3" K&N on all three bases. The 3" K&N was used on the 1" drop and the "zero-drop" base, but it was the 4" K&N that was used on the 1.5" drop rounded bottom. My apologies for the confusion. Lee
I suffer from CRS also!
Now we're doing apples to apples. Well, at least the 1.5" base LOOKS good! Thank you Lee.
David, maybe this will be of a little solice to you. The BEST power I recorded, was with the rounded base (the one installed in my bonnet, an AiRaid filter (4" high, 14" base, 11.5" at top, with an intergral "lid" made into it, with the hood closed and ALL the air coming through the hoodscoop.
Of course, this testing has me considering putting the zero-drop base into the bonnet, and making a bunch of other mods to make THAT all fit.... Lee
#38
I'm just going to use the 1.5" drop base and spacer like I have it. I don't have that much work in it (plumbed a breather line into it) and only few bucks (less than $20) including the $1.61 I paid for the spacer. And I like the way it looks. Probably won't miss 5hp out on the street. If I make one of my dragstrip runs (3 times in 10 years) I'll do something else.
I have the OEM dual snorkle air cleaner and also a steel drop base (about .75") that has a couple of holes in it in very inconvenient places.
#39
UPDATE: Just in case somebody comes across this.
Two days ago I tuned a car what had the rounded drop-base filter that I mentioned in my testing. Holley HP carb on a mild 6.0 LS. This motor put 330hp to the wheels. The filter was a 14x3" paper element. On THIS car/combo, the drop base caused ZERO loss of power. I've warned people against using that particular drop-base in the past, so felt behooved to provide results that showed positive results for it. As they say on commercials, "Your results may vary" so don't be afraid to do your own testing!
The Following 3 Users Say Thank You to Lee For This Useful Post: | ||
#40
whats the epoxy around the vent hole for? shouldn't the hole be over the vent on the carb & not turned to the rear?
