SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 11-16-2021, 04:16 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Default Complete running 455
Running 455. Have vid from the day I pulled it. Minus carb. 30 over, trw piston with stock rods and N crank. SD hand ported [before cnc] 6x#4 heads. HFT cam. 80# oil pump. Comp Hi Tech pushrods, Scorpion 1.65 rockers. Goes low 12`s to high 11`s at 3660 pounds with 3.55 gears.
$3500. Prefer not to ship.
ID:	577940   Click image for larger version
ID:	577941   Click image for larger version
ID:	577942   Click image for larger version
ID:	577943   Click image for larger version
Old 11-16-2021, 04:21 PM
PunchT37's Avatar
More pics;
No oil leaks.
ID:	577945   Click image for larger version
ID:	577946   Click image for larger version
ID:	577947   Click image for larger version
ID:	577948   Click image for larger version
Old 11-17-2021, 10:56 AM
mikesauto mikesauto is offline
Default Engine
Whats your location
Old 11-17-2021, 12:59 PM
grivera's Avatar
grivera grivera is offline
How many miles and how many runs on drag strip?
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 11-17-2021, 02:25 PM
PunchT37's Avatar
Originally Posted by mikesauto View Post
Whats your location
Lafayette,LA
Old 11-17-2021, 02:30 PM
PunchT37's Avatar
Couldn’t answer on miles. Car sits most days. And speedo wasn’t accurate for a long while. Maybe 15 passes.
Motor still has good oil pressure. Doesn’t use oil.
Old 12-19-2021, 11:52 AM
PunchT37's Avatar
TTT
This is basically a plug and play engine.
Old 01-17-2022, 04:08 PM
PunchT37's Avatar
New price. $3000. Have vid from the day I pulled it. Shows temp and oil pressure. No carb. Dist still stabbed at 12 degrees.
You can’t build a 480 to 500 hp for this. Or a stock one, for that matter.
Old 02-24-2022, 03:07 AM
Sprocket's Avatar
Sprocket Sprocket is offline
Is this engine still available?
'70 GP Model J
462 Butler ported 87cc Edelbrock D-ports
RPM intake with Holley Sniper 2
CompCams 236/242 hydraulic roller
Tribal Tubes tri-y headers
TH400 13" Continental "Jim Hand Special"
3.50 9" CurrieTrac, 245/45-18 Front, 275/40-18 Rear
Old 02-24-2022, 07:59 AM
PunchT37's Avatar
Yep.
Old 02-24-2022, 07:22 PM
Old Goat 67's Avatar
Yep, and I know this guy.
Knows his Pontiac engines VERY well.
Charles
Old 02-24-2022, 09:50 PM
BILL BOWMAN1's Avatar
How can this possibly not sell?? If I wasn’t 1500 miles away it would be in my garage !!
Old 02-24-2022, 10:04 PM
bb400ho bb400ho is offline
I could use this. If you change you mind on shipping contact me.
Old 02-25-2022, 10:25 AM
kalvert's Avatar
kalvert kalvert is offline
if you still have it when my tax refund gets here in about 2 weeks, ill take it off your hands.
Old 02-25-2022, 08:10 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Just curious - is that factory intake?
Old 02-25-2022, 10:46 PM
Tim Corcoran's Avatar
HUH?
Tim Corcoran
Old 02-26-2022, 01:42 PM
ponjohn's Avatar
Originally Posted by Tim Corcoran View Post
HUH?
What intake is that?
Old 02-26-2022, 02:33 PM
Appears to be an Edelbrock TII
Clay
Old 02-26-2022, 04:09 PM
PunchT37's Avatar
T2 with old paint. Pulled that motor as is. No paint and no cleaning to show the way it is and not to come off as a newer engine.
Old 02-26-2022, 04:38 PM
grivera's Avatar
Looks like good deal
Will Rivera
