Old 04-17-2022, 10:43 PM
BobC BobC is offline
If I can buy the correct vinyl by the yard the front seats are still doable. I’m starting the seat project while the car is still in the bodyshop. Just got first application of high build primer.
  #62
Old 04-23-2022, 01:58 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Big fan of the Recaro"s also. I've had them in my 74 since 1983. My brother had a set recovered for his 70.
ID:	589229   Click image for larger version
ID:	589230   Click image for larger version
Go fast, see Elvis!
  #63
Old 04-24-2022, 02:03 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
Those look good! I had '84 Fiero seats in my '77. Loved those deep bolsters, and the full recline.
Mike
The Following User Says Thank You to mzbk2l For This Useful Post:
  #64
Old 05-21-2022, 09:05 PM
My seat backs had a bad case of the Recaro twist. After straightening them I used some 22 gauge and made reinforcement panels. All broken spot welds were repaired. Also replaced a frayed seat back release cable. These seats had over 100K miles of use and abuse. Legendary has supplied the vinyl by the yard and shipped quickly. I have the TMI Mustang GT Recaro seat foam. Should be ready to take to the upholstery shop soon.
ID:	591286   Click image for larger version
The Following User Says Thank You to BobC For This Useful Post:
  #65
Old 05-24-2022, 03:09 AM
Hoodshaker's Avatar
Hoodshaker Hoodshaker is offline
How on earth did you get Legendary to sell you material by the yard? I inquired about getting some Hobnail cloth from them for a similar idea and I got a hard no. And I already own a set of their complete covers.
'09 Magnetic Gray Metallic G8 GT
'79 T/A Solar Gold Metallic W72/WS6
'71 GT-37
  #66
Old 05-24-2022, 08:32 PM
They had no problem selling the vinyl. I had recently ordered the rear seat cover and door panels from them. The sales person added the vinyl yardage to the same order. 10 month wait on the manufactured items.
  #67
Old 05-27-2022, 12:39 PM
Stan65 Stan65 is offline
I bought a couple pair of 81 NASCAR T/A recaro’s (thanks LadyTaTa) a few years back. Seeing the enthusiasm in this post has me thinking I need to get on the ball putting them in my 71.
Plan was to replace the foam with the TMI foam, and attempt to recover in a pattern that matches the Deluxe black upholstery. I recovered the stock seats in black Ultraleather and NOS black Comforweave. I purchased enough material to play with these.
The one pair of buckets is in pretty bad shape. I may try to save them before I “ruin” a nice pair.
Thanks,
Stan
ID:	591618   Click image for larger version
ID:	591619   Click image for larger version
ID:	591620   Click image for larger version
ID:	591621   Click image for larger version
The Following User Says Thank You to Stan65 For This Useful Post:
  #68
Old 05-31-2022, 09:26 PM
If you’re going to strip them down to the frames even the pair in bad shape can be used. New webbing is available for the lower seat. Seat back release knobs can be replaced. I modified a BMW seat back release cable to replace one that was frayed. The metal parts can be straightened and repaired with MIG or TIG. When you get them apart you will appreciate the engineering!
  #69
Old 11-06-2022, 12:23 AM
MalteseFalcon's Avatar
MalteseFalcon MalteseFalcon is offline
I just picked up a set of '81 Pace Car Recaros to use in my Fire Am project as an alternative to the Corbeau GT-8s. Since I've picked them up, I've learned two things that you may find interesting:
1. Lseat.com makes leather seat covers for them, in the original red and black colours, as well as all black, and about a dozen other colours. Front and back seat sets are $350 each;
https://www.lseat.com/products/1981-...ers-front.html
2. The Recaros that are in the 1981 Pace Car are the same LX seats that are in the 79-82 Mustangs, and TMI makes replacement foam for them. AS you probably know, the Recaro seat foam is a lot more firm than standard foam, almost hard. They are available for about $250 per side from CJPonyParts:
https://www.cjponyparts.com/tmi-seat...1982/p/SF19-V/
Steve
1978 WS6 W72 4 Speed Trans Am - Martinique Blue on Light Blue - Fire Am Restification Project
1972 4-Speed 455 HO Trans Am - Original Cameo White on Blue car - Restoration Project
The Following User Says Thank You to MalteseFalcon For This Useful Post:
  #70
Old 11-06-2022, 10:18 AM
78w72 78w72 is offline
those covers look nice, are they just a slip on cover or are they actually replacements that require disassembly of the seats to install?
  #71
Old 11-06-2022, 10:28 AM
GoreMaker GoreMaker is offline
They're replacements that require installation with hog rings.
I'm confused about the foam, I don't see the grooves in the backrest that the cover fits into.
The Following User Says Thank You to GoreMaker For This Useful Post:
  #72
Old 11-06-2022, 10:51 AM
I wonder if those covers fit Recaro LS seats? Not sure if the LS bolsters are taller.
  #73
Old 11-06-2022, 11:33 PM
Maxthe222 Maxthe222 is offline
Talking
King seats for any Firebird, I am putting a set of VSE spec Recaro 1981 IdealSitzN's back into my Fire Am and having them trimmed in the factory Carmine Red Hobnail material, just like how GM did with the K-Types.
The Following 2 Users Say Thank You to Maxthe222 For This Useful Post:
