OHC-6 TECH Over Head Cam projects, questions and advice.
Old 02-07-2024, 03:17 PM
Cammer-6 Cammer-6 is offline
Default factory AC owners,what ignition are you using?
Anyone thats fiddled with the distributor,fighting that compressor bracket,
will realize its a cruel joke. Its actually quicker to move the bracket for distributor access.
Whos running something other than points,ie Pertronix, Mallory ,TI,etc?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 02-07-2024, 06:47 PM
sprintbird sprintbird is offline
Most are running Pertronix or points.
Old 02-08-2024, 11:54 AM
I am still running points, but with a vintage Mark 10 Capacitive discharge ignition system. It seems to extend the life of the points quite a bit.
Here is one on Ebay, Just so you can see what it is. I carry a NOS spare just in case.
https://www.ebay.com/itm/145451958399
Old 02-08-2024, 12:16 PM
Bill Hanlon's Avatar
I had a Heathkit (build it yourself) version of the Mark 10 CDI that I built in the 70s on a '65 Chevelle, moved to a '77 Honda Accord that went 200,000+ miles and was later installed in my 347 Pontiac powered '57 GMC truck. The only reason I had to replace the points in any of these vehicles was that the rubbing block would wear down enough that there was not enough adjustment left to get a proper point gap. Good part.
Old 02-08-2024, 06:37 PM
Dad also built a Heathkit one for our 63 GP and ran it until the car was traded around 68.
I currently have a pertronix in my AC 67 Sprint.
Old 02-08-2024, 07:00 PM
694.1 694.1 is offline
Got an old Mallory hidden under the wiper cowl. Long discontinued, I bet I bought it in the mid 80's?
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 02-08-2024, 10:26 PM
I ran the Mallory in my 68 Firebird 400 for years
It did refuse to start one afternoon at work.
Got a ride home and brought back a spare control module
and it was running again.
I ll look for it for spares for you,took it off when I sold car.
Old 04-20-2024, 02:37 PM
Another thread about failure of the pertronix units have me nervous.
wondering if its possible to use the CD/TI ignition systems internal parts
and a more modern control unit.Anyone know how to accomplish this?
whos got a converted GM HEI unit to test fit and see if it will fit under the OHC6 AC compressor mount?
forgot to mention I have factory tach/gauges
Old 04-20-2024, 10:48 PM
This may be way off base, but my '52 GMC 228 cubic inch six cylinder is running Chrysler six cylinder mag pickup and reluctor (circa 1977) inside the stock distributor. The ID of the reluctor has been machined to slip over the cam that operates the points (which have been removed along with the condenser).
Two signal wires ( + and - ) leave the distributor body and find their way to a GM HEI module I have hidden inside the original voltage regulator box on the firewall. The other two pins on the HEI module trigger a Blaster 2 coil, which has similar specs to a GM HEI coil.
The guy I got the parts from may be open to trying the same (totally reversible) mod on an OHC6 distributor. Here is his write-up on doing the mod to an old Chevy/GMC distributor. http://devestechnet.com/Home/HEIgnition
Old 04-21-2024, 08:40 AM
Bill thanks for that
This is about the same as what I was asking.
I have spare guts to a CD/TI distributor as well as a pretty complete 66 TI system.
Will this work for a trigger on someone elses control module like youre using or an MSD?
I miss being able to ask Padgett ::^(
Old 04-21-2024, 11:55 AM
Will this work for a trigger on someone elses control module like youre using or an MSD?(
Sorry, I don't know.
