12 Bolt Carrier? Posi.
No real identifying numbers here that I can chase but this looks like a GM 12 bolt carrier. Maybe ya'll can help. Years, interchange?
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
EDB 30142 ? Trying to read the last casting number
Not a c-clip axle 12 bolt carrier...
With the shape of the carrier & the 2 spring preload plate setup, believe it is one of the three different ratio 65-70 Pontiac "P series" big Pontiac Safe-T-track carriers. Had these carriers identified by their Eaton casting number, but lost that info with pics on my old Dell laptop when the screen went out. 65-70 Big Pontiac Tech section should be able to ID.
Buzzards gotta eat... same as worms. Last edited by 'ol Pinion head; 06-02-2023 at 05:40 AM. |
I agree with OPH. Just looking at the pictures of my 68 Catalina posi unit and it's pretty much identical. Only difference is mine says 152 where yours says 148. Which series carrier it is is still in question though. Mine is the first series ( 2.29, 2.41, 2.56 ratios) FWIW.
30148 is the low ratio unit. 3.23:1-up.
So long, farewell. |
The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
You guys are the best!
I have a second one with a 3.42 R&P.
The Following User Says Thank You to 694.1 For This Useful Post: | ||
