Old 12-18-2017, 07:59 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Default upgrade ordered! Northwind intake ?
I am upgrading my heads, doing a cnc port and just ordered a Northwind intake to match! Merry Christmas to me!!
Anyone ever use one for boost before??
Old 12-18-2017, 09:36 PM
Tom Vaught's Avatar
Boost Engineer
Never had a Northwind before but typically (speaking from history) a GOOD NA manifold will be a good Boosted Engine manifold as in reality all you have done is change the Density of the Fuel and Air Mixture (with boost) and the CFM of the air/fuel is very close to the Naturally Aspirated CFM Air/fuel flow.
Because the Air Density is higher you need more fuel to maintain the same air/fuel ratios.
Never heard anything bad about the Northwind intake only good.
Tom V.
Old 12-18-2017, 10:41 PM
JSPONT's Avatar
Thanks Tom, It is a little shorter than the victor so hood clearance is not an issue. rpm range seems to match my cam well. I have the knock off HSD on it now with a spacer plate.
Old 12-19-2017, 09:02 AM
Curious George's Avatar
Curious George Curious George is offline
I'm running a Northwind intake on mine.
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
Old 12-19-2017, 03:23 PM
JSPONT's Avatar
Can you post a photo? How do you like it with boost??
Old 12-20-2017, 09:34 PM
No complaints. Last photo is during mock up.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 12-20-2017, 09:55 PM
JSPONT's Avatar
Can't see them on photo bucket
Old 12-21-2017, 09:13 PM
UGH! PM me your email or text and I can send them that way if you wish, and/or take specific pics you'd like.
