Old 10-18-2022, 06:35 PM
JUDGEMAN70 JUDGEMAN70 is offline
Default Ebay Classic Exhaust for 70 Judge
Has anyone used Classic exhaust? Much less than Gardner exhaust. Wondering about quality and how close to original. https://www.ebay.com/itm/144543270425
thanks
Old 10-18-2022, 09:16 PM
Our sponsor, Ames, markets a damn good setup made in Nebraska to order - excellent fitment and very fair price.
Old 10-22-2022, 03:04 PM
23337 YT's Avatar
23337 YT 23337 YT is offline
I purchased the system. It came with two different mufflers. When I asked about it, I received a three word reply "They are interchangeable.", so not really thrilled with the customer service. I haven't installed the system yet so I can't speak to the fit. I did think the picture on eBay looked better than what I received. I was looking for a complete system, at a lower price, that I could install at home without too much wrangling. I'm sure it doesn't compare to the Gardner system, but as you noted neither does the price.
ID:	600934   Click image for larger version
Old 10-22-2022, 03:34 PM
ID67goat's Avatar
ID67goat ID67goat is offline
I looked up those mufflers that you received on Summits website and while they are the same physical size Summit shows that one is a baffled muffler while the other a “stamped cartridge” whatever that means. The mufflers are cheap if you wanted to order another to make them match.
Not sure I would want to run 2 different styles of muffler..
Old 10-22-2022, 09:12 PM
Tom Hand's Avatar
Tom Hand Tom Hand is offline
Exhaust Guru
The factory setup on many of the GTOs were two different mufflers. They had shorter one on the pass side as it had the heat riser in the manifold.
The stamped cartridge is neat setup they came up with that you saw a lot on big Ford and Lincolns in the early to mid 1990s. Cheap to build but pretty slick design.
Tom Hand
