Clutch Springs
I am trying to figure out where the clutch return spring mounts to. I know one end goes on the Z bar. And the other end on to a equalizer shaft mounting bracket. What is that? Where abouts is the location of it. And is it a bolt on bracket.. Thanks again. Tom
ie: Year, Model, Engine, Trans ???
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
Ah yes it would. Sorry about that.. 70 gto 400 4 speed
No worries . . .
This illustration from the Pontiac MPC should be helpful.
I have that. But i dont seem to have that on the car.just wondering if that is bolted or welded on the frame rails or some other location
Anyone?
Found this in a 69 factory manual.Looks like its going to the bracket for the backdrive linkage ? Let me know if it will work because I have the same question.
John |
for some reason my car dont have that. Im trying to figure out the location and if it was welded on. Or bolted on from the factory. Tom
It bolts to the frame, almost across from the from of the trans. The backdrive linkage goes into the big hole on the left of the bracket. The next small hole to the right is where the spring would go.
John |
Thank you. Thats the info I needed. Now I just need to locate one..
No problem, I wasn't 100% on it myself. Pretty sure 69 and 70 is the same. Happy parts hunting !
Bolts to the frame right by the brake distribution block:
Ames\PY sell it and the screws to mount it. |
Good deal..Thanks for the pic....
And for future reference, here's a picture of everything hooked up:
