Old 08-02-2016, 02:07 AM
West Coast GTO's Avatar
West Coast GTO West Coast GTO is offline
Default 1971 shoulder belts
I have researched the threads to try to determine if Pontiac installed shoulder belts on front seats on a 1971 GTO. I see the custom seatbelt options of 451 and 452 but does that mean that without either option the factory installed basic seat and shoulder belts or just seat belts?
Thanks.
Old 08-02-2016, 06:52 AM
Judge273's Avatar
Judge273 Judge273 is offline
Mandatory shoulder belts on fronts for sure...
Mike/Illinois
Old 08-02-2016, 12:10 PM
A.W.Dille A.W.Dille is offline
My 71 has them, factory original.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 08-02-2016, 02:21 PM
Jack Peters's Avatar
My T-37 has them.
JLP
Old 08-04-2016, 07:51 AM
Eric71T37's Avatar
Eric71T37 Eric71T37 is offline
My '71 T-37 two door hardtop has them (factory installed). Almost certain they were federally mandated for '71...except convertibles.
_______________________________________
1971 T-37 Laurentian Green/Sandalwood buckets
455/1971 #96 heads/TH400/3.31 12-bolt posi/4-wheel discs
Old 08-04-2016, 09:34 AM
tigergto's Avatar
tigergto tigergto is offline
My 71 GTO has the front shoulder belts and no where on my build sheet are the option codes 451 & 452, so they have to be standard. I know they're factory installed.
Old 08-04-2016, 11:40 AM
Talking Shoulder selts
The previous owner of my new-to-me 71 GTO installed a headliner as well as a carpet set and neglected to install the shoulder belts ( or just didn't like them). I guess I am now in the market for a set because I do use them while driving.
Old 08-09-2016, 05:54 AM
Eric71T37's Avatar
At least it will be a fairly easy install...the threaded holes are there in the roof behind the headliner. Don't forget the loop retainers for keeping the shoulder belts tucked away when not in use (the holes are there for those too).
Old 08-09-2016, 06:05 AM
Eric71T37's Avatar
Here are a couple of pics for reference...note the headliner bow locations...are your coat hooks there?
Old 08-09-2016, 06:06 AM
Eric71T37's Avatar
These are the optional custom deluxe belts by the way (in Sandalwood).
Old 08-09-2016, 12:01 PM
No coat hooks installed. The headliner installed left a clean slate on his install. No evidence of any shoulder hardware.
Old 08-09-2016, 04:43 PM
tigergto's Avatar
Dumb question but what makes them a custom deluxe belt? Is it the stitching?
Old 08-09-2016, 05:53 PM
I believe that it is the latches. My 70 GTO had the deluxe seatbelts with this configuration. My 71 has the basic black plastic latch.
Name:	SAM_5960 (640x480).jpg
Old 08-09-2016, 06:43 PM
tigergto's Avatar
My 71 has the basic black latches. I do like the looks of the custom latches. Gives the interior a little more eye appeal.
Old 08-09-2016, 06:56 PM
Eric71T37's Avatar
The custom deluxe seat belts are color-keyed to the car's interior color. The buckles are either brushed metal like mine, or coated the same color as the belts/interior.
Standard belts are all black with black plastic buckles. There are black custom deluxe belts, with either the brushed metal buckles or coated black buckles depending on the GM variant.
Tell-tale way to quickly identify custom deluxe belts...the male metal end that goes into the buckle has a square hole rather than rectangular (see photo I posted above of my shoulder belt).
Old 08-09-2016, 07:02 PM
Eric71T37's Avatar
I have found that the best donor cars for custom deluxe color-keyed belts, with either the brushed metal buckles or coated buckles, are Oldsmobile Cutlasses and Pontiac Grand Prix. Other good sources are Toronados, Rivieras, Skylarks, and Cadillacs. Maybe Monte Carlos. Not common in Pontiac A-bodies and Chevelles.
I put my '71 brushed metal buckle set together from a '71 GP and a '71 Cadillac coupe, plus buckle pieces and covers from various other cars (all in salvage yards).
Old 08-09-2016, 07:04 PM
Eric71T37's Avatar
'71 Custom Deluxe seat belts with brushed metal buckles
Old 08-09-2016, 07:08 PM
Eric71T37's Avatar
Nice deluxe belts. I always look at the seat belts now in any GM car at shows...so few cars have deluxe belts, especially with the brushed buckles.
