#61
And what all do I need to be asking done? Can a reputable machine shop do it or should I stick to pontiac gurus? There is a machine shop not far from me, I know they are good with sbc stuff, but all that doesn't correlate to pontiac Sent from my SM-G996U using Tapatalk |
#62
The Following User Says Thank You to PAUL K For This Useful Post: | ||
#63
Newb Question. Why would you start with a set of 6x heads when a 62 Head is a better head? Is it to keep compression down?
Sent from my iPhone using Tapatalk |
#64
Far easier and more efficient to simply buy a set of KRE 72cc D ports than ship heads across the country and you still can run higher compression.
The Kauffmans made these specifically as replacements for street cars. |
The Following User Says Thank You to Scarebird For This Useful Post: | ||
#65
That's kind of where I stand when it comes to this dilemma.
By the time I have a set of factory iron heads done, new guides, seats, valves, springs, positive seals, all the machine work needed, I'm usually in for $1000 or a little more than that right off the bat. Toss in some labor for someone that knows how to port a cylinder head and flow bench time and the price can go as far as you care to take it. So unless it's for some sort of numbers matching deal and needs to be absolutely stock appearing, I tend to lean towards a good aluminum cylinder head when you start getting up in that price range. I like iron heads, but to do them and do them right is just not a very cheap proposition anymore. So very few shops I even trust with machine works these days. To add to that, I'd never run a set of aluminum heads right out of the box either until I've had a reputable place go through and at a minimum check them out for guide clearance and valve job etc.... Anymore, if it's feasible, I also like to have them flow tested just to see if they are what the manufacture claims. Last edited by Formulajones; 10-21-2021 at 10:09 AM. |
The Following 2 Users Say Thank You to Formulajones For This Useful Post: | ||
#66
#68
#69
Don't mean to hi-jack this thread but maybe someone can explain:
If a pair of ported iron heads would out perform a pair of new aluminum heads and both were the same price why would one lean towards the aluminum heads? |
#70
You said you would take the 6x heads and have them extensively ported. I am asking the forum more of a General question, why do many people use the 6X head which is typically a later less performance head than let’s say a 62 since we are on the topic of D-Ports. Why would someone use the 6x vs a 62 head if available? I’m just curious. Trying not to take this off topic. Sent from my iPhone using Tapatalk |
#71
"why would one lean towards the aluminum heads"
Not posted as a specific answer, but offering the topic of some aluminum heads providing more modern features like a heart-shaped combustion chamber and improved spark plug placement. That said, if the alum head and the iron head had the same flow curve would the chamber design make any difference. Other that say the timing issue. ??? Types of Combustion Chamber: Functions, Advantages & Disadvantages .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 10-21-2021 at 03:05 PM. |
#72
#73
#74
6Xs have a better basic port design.
#76
I am with you there young man! 💪💪👋😴
#77
Thanks Paul.
Your testing indicated no noticeable power improvement. That somewhat follows Dave Bisschop's small 10 HP gain with the heart shaped chamber on 310 cfm CNC Edelbrock heads. He did find peak power was achieved with 2 degrees less timing. I had a friend bring one of my original '70 d-port iron heads down from my attic for me to measure something. That was about a year ago and it's still on the garage floor and not returned to the attic. This OLD MAN even has a hard time lifting it .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 10-21-2021 at 05:14 PM. |
#78
6X-8 heads will be about 98cc's after a clean up mill and be used with stock flat top piston for a street friendly compression ratio of about 9.3:1. 62's after a cleanup mill will come out about 72cc's and will require a piston with a 31cc dish to keep the same street friendly compression ratio.
#79
Get the car running right. Worry about the other stuff down the road.
5C vs 6X w stock ports are nearly identical. If ported, the 6X is better. Both are large chamber heads (8's) so your compression is quite low on a 400 (around 7.6:1). You would need to mill them to the CR up. As far as the sooty exhaust, if the car runs fine, is not loading up at idle and stalling, etc. I think you just need a choke adjustment since your idle vacuum is fine. Again, don't put the cart before the horse. Optimize what you have through tuning and you may be happy with it just the way it sits. Get your carb dialed in and you'll be fine. That timing is a mystery but again, it wouldn't run if that far off. If it was BTDC, I'd wager you clipped it to the #2 cylinder which fires 45 degrees before #1.
Triple Black 1971 GTO |
#80
