Anti roll bar install
Just installed my Hrpartsnstuff anti roll bar.....birthday present to myself
All I can say is WOW! The quality of this kit is incredible. Transformed my old slug 100% Leaves absolutely straight. Car handles better than I ever expected....awesome on the street! Can’t wait to hit the track....I feel some 60’ improvement forthcoming
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
The Following User Says Thank You to mchell For This Useful Post: | ||
They make nice stuff. Enjoy
'65 Tempest 467 3650# 11.30@120.31 |
I am running the same style but the BMR brand. It replaced a weld in anti-roll bar. Made a huge difference. Car straightened out and picked up in the 60ft. Went from 1.40 to 1.37 no other changes.
Very clean and efficient design. Looks great as well with zero obstruction or fitment issues.
After going back and reading the information, mine actually mounts to the crossmember too
My brother put one on his 1970 last summer and it works excellent. Very good product.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
Nice! I just did the entire rear with the BMR version, adj control arms, no hops, qa1 dbl adj shocks and track locator on my 70.
cant wait to test it out. On the street, drives great. Bought the Dick Miller weld in Anti Roll bar, but there is no way it fits with regular springs and 3" over axle pipes.
[SIGPIC] Steve |
fronts are just Calvert drag shocks. 90/10 and stock springs. I didnt weld the Anti roll bar mounts to the axle tubes yet. i marked them to see if they move. If they move, I will weld them.
that pic is pre install of all this stuff. only had boxed stock control arms and front drag shocks. i had wheel hop after the initial launch. stick car.
[SIGPIC] Steve |
My low 10 sec 70 GTO would wag it's tail ALL the way down the 1/4 mi giving me the white knuckle ride.
Put the HR bar and all the stuff on, now the car is straight arrow driving with 2 fingers. It works !
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Good to hear, just put the HR parts n stuff bar on mine as well. Can't wait for hammer time.. Had to remove the jack plate on my 9". Paul said you definitely want clearance so no binding.
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and 9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches.. |
I fabricated my own set-up, more like seen on some trucks. I used an aftermarket factory Pontiac rear sway bar because I had already purchased it not knowing I could not use it with the Ford 9". I made all my own brackets and mounted it backwards to the rear frame rail. This is on my '68 Lemans. Don't know how well it will work as the car is still in the build stage, but I think I am good. |
What clutch set-up you use? GT. |
Here’s a pic of end link and bracket geometry......3” tail pipes
Still smiling every time I drive it....
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile Last edited by mchell; 05-17-2020 at 10:38 AM. |
About how long are the end links?
Center to center is close to 4” (That’s threaded all the way in)....I would guess they can be backed out another 2-3”
How did you set neutral preload?
Leave the end of the passenger side adjusting bar unhooked; then with the driver in the car install it where the bolt for the adjuster will slide in by hand and tighten the jam nuts.
