Old 11-09-2023, 02:14 PM
Jason67's Avatar
Jason67 Jason67 is offline
Default 1112012 455 HO distributor
I have (2) 70 455 HO distributors, a 9K21 and a 9L18. I'm trying to determine if the shafts are correct. The 9K21 is stamped 716 CW on the shaft, and the 9L18 is stamped 534 CW. Is there a reference on distributors that shows what shafts are supposed to be installed? Thank you
Jason
Old 11-09-2023, 03:28 PM
Kenth's Avatar
Kenth Kenth is offline
All 1970 455 distributors uses a 1946277 CAM stamped CW 716, the two last digits reflects the max amount of centrifugal advance, in this case 16°.
The 1846209 SHAFT in these units are stamped 33W.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-09-2023, 04:23 PM
Jason67's Avatar
Thank you Kenth, much appreciated!
Jason
