'63 Tempest 326 Oil Pan Removal (to fix a leak)
Has anyone been able to remove just the oil pan on their '63, with engine still in the car?
The stock exhaust manifolds hug pretty tight to the engine. I cannot remember exactly, as it has been a while, but I think I have previously R&R'd the engine with the exhaust manifolds attached to it. Anyone else? |
Don't think it is possible with everything bolted in place. Perhaps disconnect the propeller shaft (correct name for the rope shaft), torque tube, and then lift the engine a few inches. Hopefully that will get the clearance that you need.
If you built it, drive it. red 62 Tempest total stock restoration. white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train. |
As I remember it when I tried it the engine has to come up more than a few inches to clear the oil pump.Been a lot of years.Tom
Thanks. I will just pull the whole engine, in case it's the rear rope seal that's leaking. I usually separate the crank bolts and the bellhousing from the engine, not the torquetube to the bellhousing. That way, you can lift the engine straight up.
I had to install the crank to ropeshaft bolts with red loctite because they kept coming out. So I will probably need to use some heat to get them loose now. |
