Old 04-24-2023, 11:47 AM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Default Tri-Power Air Cleaner base-OE
Looking for original tripower air cleaner bases, want OE only, thanks
Old 04-24-2023, 02:59 PM
1lms 1lms is offline
48 state or CA?
Old 04-24-2023, 04:36 PM
Sloan66's Avatar
48 states
Old 04-24-2023, 07:18 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Hi Kevin,
Other questions need to be asked?
Base or bases?
GTO or big car?
Not sure if you need a single or all three?
Small 64-65 center or 66 large?
Chris.
Old 04-25-2023, 07:53 AM
Sloan66's Avatar
Thanks Chris for the follow up questions, did not clarify as I needed to do.
I need 3 non-A.I.R. bases for an original '66 GTO tripower. I realize some may have bases and lids and not want to break up set, open to that as well.
Thanks again for the help.
The Following User Says Thank You to Sloan66 For This Useful Post:
Old 05-02-2023, 09:42 AM
Sloan66's Avatar
Bump
While I want all three, I am willing to buy one at a time. So, if anyone has just one, let me know, thanks
