Motor mount fitting first
Going through some pictures I found a "tool" I made for the motor mount "adjustor" I needed when I added the IA in the Camaro.
I had not checked the mounts to see if they slide on the frame mounts(correct Firebird mounts). So trying to stab the motor was not going. Mounts were a tab tight so had to be "stretched" a hair. So save yourself some headache and check the fit first!
Necessity is the mother of invention with car stuff many times!
I do stuff for reasons. |
