Old 07-16-2023, 06:30 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Default 1965 # 77 heads - bolt on and run
These have been sitting after I went to kre. Heads ran perfectly on my car. Receipt with work included. # 77 the hi-po heads in 65. Date code is B185.
Been about 500 miles since work was done. I just cleaned them up a bit with paint and acetone on chambers.
Screw in 7/16 arp studs, new style seals, adjustable guide plates. Push rod holes opened up for 1.65 rockers. $1100 local pick up. May consider shipping, but these things are heavy, will not be cheap.
ID:	616191   Click image for larger version
ID:	616192   Click image for larger version
ID:	616193   Click image for larger version
Old 07-16-2023, 07:04 PM
TOYSWEDO TOYSWEDO is offline
Default HEADS
HELLO. interested IN THE HEADS
IM IN NY
EMAIL ME WITH YOUR NUMBER...
WE CAN TALK...
TOYSWEDO@AOL.COM
Old 07-16-2023, 07:51 PM
Toyswedo - Ill send you an email.
Old 07-16-2023, 09:57 PM
Receipt pick
Old 12-02-2023, 12:59 AM
Ttt
Old 01-18-2024, 03:00 PM
cardoctor98 cardoctor98 is offline
Default #77 Heads
Do you still have these Heads?
Interested...
Email me 40Pontiac26@gmail.com
Old 01-19-2024, 12:48 AM
I do have the heads but you look pretty suspicious with your zero post count and public email. Mods what would u say?
Old 01-19-2024, 02:16 AM
Well as long as you handle payment to your satisfaction what’s to worry about ?
Old 01-19-2024, 12:28 PM
I suppose that is true b-man. Still feels a bit like email address harvesting to me. I get enough junk email
Old 01-19-2024, 12:51 PM
Then use PMs here instead of email.
Do it your way or not at all.
Old 01-20-2024, 02:07 PM
Never Mind, found another set cheap....
Does not have the screw in rocker studs, but I am building a light power street rod, so wont matter too much. I am not one of those guys that needs to squeeze every ounce of power out of an engine. Running a Hyd Cam, (non-roller) and want to make this engine very dependable without breaking my bank account...
Old 01-20-2024, 07:24 PM
Good to hear u were legit. Happy it worked out. I have to work on my web skepticism
Old 01-20-2024, 08:16 PM
No worrries, I get it....
I am new to the Pontiac game....
Switched sides.
Was always a FORD Guy for years...
Old 01-20-2024, 10:14 PM
Welcome to the family. Counter clockwise 18436572. �� A lot of great support on this forum.
Old 01-20-2024, 10:15 PM
Welcome to the family. Counter clockwise 18436572. 🤟 A lot of great support on this forum.
Old 02-14-2024, 10:14 AM
Thanks Guy's. I am probably going to need it...
Keep making mistakes that are costing me $$$
For example, wish I never would have bought a 1963 block... DUH! should have researched it first on here...
Old 03-31-2024, 05:27 PM
TTT
