Old 09-11-2021, 05:37 PM
gtorich gtorich is offline
Default 66 Gto trunk lid issue
Key word here is looking for some "free" info. lol
Any ideas on how to make this look halfway decent.........seems the gaps are not too bad, i can adjust the latch on the lid, only helps in closing it one way or the other..........
The pics of the gap from the side look alot worse than they really are, but no matter i would like to fix this issue up some.
Any ideas on what to try................im thinking the bottom line is bending the trunk to fit, but even if i did that wouldnt everything even be more off. ?????
Hope you guys have some thoughts on this.
Rich
Name:	Trunk lid (2).JPG
ID:	572839   Click image for larger version
Name:	Trunk lid (4).JPG
ID:	572840   Click image for larger version
Name:	Trunk lid (5).JPG
ID:	572841   Click image for larger version
Name:	Trunk lid (3).JPG
ID:	572842   Click image for larger version
Name:	Trunk lid (6).JPG
Old 09-11-2021, 06:57 PM
400 4spd.'s Avatar
It shows symptoms of being hit dead center in the past, with the floor too high. Also looks to me like it needs to be adjusted forward. If it will go forward, do that first.
If you can push down on a corner, does the opposite corner rise or stay the same? If it rises, there is a gap between the rubber lid bumper and the body. The fix is lowering the latch. If all downward adjustment is used up, the center support is probably too high. See sentence #1.
Old 09-12-2021, 04:02 PM
Thank you 400, i can push a little on the pass side, doesnt do anything with the ds though............will try to move it a little forward, doesnt seem like much room there though..........was a a show today near milwaukee, alot of gto"s of course nothing that looked like my trunk lid. lol...............so im taking it, if the floor is too high, doesnt really matter what i do , its gonna be off.
Rich
Old 09-12-2021, 04:08 PM
Didnt think of that untill now...........any other signs that i could tell if hit in he rear at some time in its past............of course to my untrained eye, everything looks ok. lol
So im thinking the other only thing i can do is bend the trunk lid to where it needs to go, then have the lid repainted.
Rich
Old 09-12-2021, 05:44 PM
Your plan may be the only way to go at this point. If the latch is allowed to come down, it will close that gap and the other side will probably stay up enough due to compressing the weather strip on that side.
Old 09-13-2021, 05:55 PM
Ok, heres where im at today............took the stops off, latch out, weatherstrip out, looks pretty good. lol......really not to sure on how to proceed, the latch connected to the trunk only moves a little one way or the other, i messed with the latch connected to the trunk frame..........not getting any better moving that around , it only moves a 1/16 if that.
Didnt want to try moving the lid back further by myself, but that looks like it would only move a 1/16 at best.........but will give it a try.
Other option, i bought a spare lid years ago, could throw that one on and see what that looks like.
Can try some different weatherstip, think i have the soft seal brand, this will be my 3rd set, seems like im not getting what others have on their gto.
Rich
Name:	Trunk lid 1 (1).JPG
ID:	572988   Click image for larger version
Name:	Trunk lid 1 (3).JPG
ID:	572989   Click image for larger version
Name:	Trunk lid 1 (4).JPG
ID:	572990   Click image for larger version
Name:	Trunk lid 1 (5).JPG
Old 09-13-2021, 05:57 PM
You can see on the ps side, still a gap, looks alot better on the ds.
Rich
Old 09-13-2021, 06:12 PM
Jeff Hamlin's Avatar
Default FWIW...
I had a trunk seal issue and decided to do a comparison test.
I ordered a few of the top seller's offerings for "Correct" 1966 Trunk Weatherstrip and this is what I found.
This may help you pick the one to help with this issue.
Cheers.
ID:	572992   Click image for larger version
Name:	WEATHERSTRIP SIZE COMP 1.jpg
Old 09-13-2021, 06:33 PM
Cheers.
Jeff, thanks for those pics.............these are two of the ws i have laying around, sad you have to buy three sets and hope you get something that fits.
Seems like the only difference is in the size of that slit...........will check on what i have on the car.
Rich
Name:	Trunk ws (1).JPG
ID:	572995   Click image for larger version
Name:	Trunk ws (2).JPG
The Following User Says Thank You to gtorich For This Useful Post:
Old 09-13-2021, 10:16 PM
MUSLCAH MUSLCAH is offline
Elongate the mounting holes in the latch ..or catch…to get that lid to draw down. It looks pretty good in the pics ,with your hand holding it shut.
Old 09-14-2021, 09:27 AM
Im gonna give that a try, think i have a spare latch piece to do that with..........but remember those pics are with everything off.........hope this does the trick.
Rich
Old 09-14-2021, 10:51 AM
If pushing with your fingers closes that gap, a tighter latch should do it. The side pic I was assuming was also with you pushing, but if that is just laying there free from pressure, the latch should do it if it can latch tighter.
Old 09-14-2021, 06:54 PM
Ok, messed with it today some............got it to move forward some, really not much change in the back though, and its a hair away from chipping paint towards the rear windshield.
After messing around all afternoon, almost got it back to where i started. lol
Hope im doing this right, my wife was on one side, me on the other, loosened both hinge bolts and tried moving from side to side..........not really much adjustment that way, just seems like i cant get it centered right, seems it moves some but when you tighten the bolts back up, it always moved too much. I finally give up for the day.
Read some posts about bending the hinges with a 2X4........not sure how that would work with good paint on the lid.
Any other tips would be appreciated.
Rich
Old 09-14-2021, 07:29 PM
I'm not sure bending the hinges will address the rear of the lid.
You may want to apply several layers of painter's tape around the gutter just in case you have a slip with the lid.
Also may have to elongate the hinge holes slightly for more adjustment of the lid.
Old 09-14-2021, 07:33 PM
I don't think I'd mess with trying to tweek hinges. You don't want more problems than you have. I'd be more inclined trying to tweek the lid. With some wood and blankets strategically located under that corner, try pushing down to actually bend it where you want it to be. Trial and error. Little at a time.
Old 09-14-2021, 07:59 PM
tjs..........hate to sound dumb, but your talking about doing this with the lid off i presume. lol
oh boy, i can see paint a flying...........im assuming im gonna have to get this lid painted one way or the other with all my messing around.
Jeff, posted in the 66-67 section, but does this gap look about right to you on the topside of the lid...Also may have to elongate the hinge holes slightly for more adjustment of the lid.
Im taking it you mean to elongate them so i can go side to side a hair..........im thinking i might have to go tjs 72"s way, still a ways off on the other end
Is this gap i have now along the top, about normal, the ends seem off, nothing i can do about that.
Rich
Name:	Trunk Pics (4).JPG
ID:	573044   Click image for larger version
Old 09-14-2021, 08:03 PM
A better pic of the corners.........you guys think i can still move that lid a little bit more forward.
Rich
Thanks for hanging in there with me. lol
Name:	Trunk pics (8).JPG
Old 09-14-2021, 08:47 PM
400 4spd.'s Avatar
Rich, in the pictures I based that lid-forward suggestion on, the lid molding appeared to extend back further than the quarter moldings. On some cars, getting that area 100% isn't possible. Maybe that's the case with the 66.
Because the lid turns downward for several inches at the rear edge, if the lid is sitting back it amplifies the gaps to the quarters.
Rather than typing an elaborate process of adjustments and how to get out of trouble on adjustments, I'm going to PM my number to you in case you want to discuss things tomorrow.
Old 09-14-2021, 10:17 PM
All these restoration shows just ruined everyone’s expectations of their car. These things fit like that from the factory …..And when you went to a car show in the 80’s ….we’re you looking at “Gaps” Heck no….you were looking at the car overall. But times have changed ……….
Old 09-15-2021, 11:06 AM
I don't think messing with your hinge slotting or front to back is going to help your issue.
I do mean trying to bend a tad while on car and protected to see where it gets you. If no progress, yes the lid has to come off. A wood template cut (use cardboard as a template for wood cutout) to contour of quarter panel. Use the template as a guide to how well it fits after trial bends. Then on car off car until your satisfied. I had to do this recently on a 72 GTO hood that was bowed up in center about an inch above fenders due to someone else's problem (probably bad hinges). I had to clamp hood between 2x4's and a long one inch bar of steel to get right. Now it fits perfectly.
