Hello there I currently have a holley on top of a 1" spacer plate.
The spacer plate has a fitting in the rear which connects a hose that goes to brake boster. The hose is a fairly decent size. For sure a brake hose. I'd like to remove the holley and put a rochester on so I can pass emissions testings. My intake as mentioned in the subject is a performer RPM. If I remove the inch spacer and install everything to the rochester I'm left with the brake hose not going anywhere because I believe I have a chevy carb( it's ok it's just for emissions testing ) My PCV valve incidently use to go into the rear of the holley. Where does that go on a Rochester. On the front of the Rochester , the bigger of the two entry locations. Generally speaking it looks like this one in the link and I would plan on buying this for my car: http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874581550 My 1" spacer has the 4 corner threads that stick up. I know this method won't work with Rochester because the screws go downward on the front. I'm aware the choke wouldn't work on the manifold I have now. Any suggestions with where the brake boster goes? The pcv would probably require a different hose to go to the front of rochester. Maybe I'm answering my own questions. I currently have a rochester that doesn't even have a connection in the rear for a brake ( maybe it's a chevy ) ... I could run with it but where would I put the brake hose in the mean time? Where is the pcv inlet on the front? Any help guys. Thanks
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane |
Maybe that was a little to long winded?
How about can anyone tell me if I can run a brake booster line to the RPM manifold?
I found out the RPM manifold has a fitting in the rear for the brake hose to go into.
Thanks. I'm going to buy that and have a direct feed.
OK
--------------------------------------------------------- "...And on the seventh day God raced his GTO!" ---------------------------------------------------------
--------------------------------------------------------- "And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor?? --------------------------------------------------------- |
