Old 07-21-2021, 04:40 PM
NeighborsComplaint's Avatar
Default SBF 1.6 Rockers on Pontiac no clearance issues?
An old timer "Pontiac Guy" told me that the SBF rockers in 1.6 ratio will work on non-clearanced Pontiac heads so long as the pushrods are 5/16" and not 3/8" RAIV and lift does not exceed .550" with them in place.
Like they say, trust but verify. Any truth to that?
Triple Black 1971 GTO
Old 07-21-2021, 05:24 PM
Steve C. Steve C. is offline
Yes here with some:
https://forums.maxperformanceinc.com...34#post3577934
Old information here:
Old 07-21-2021, 05:37 PM
Schurkey Schurkey is offline
I have "small-block Ford" roller rockers on an Olds 455. They "fit" and "work", but because the valve angles are different (Olds has 7 degree valve angle, SBF has...20 degree valves (?)) the geometry isn't perfect.
I'm thinking that Pontiac is closer to SBF than Olds is, but I haven't confirmed that.
As always, verify the width of the contact pattern, and the contact pattern's placement on the valve tip. Wouldn't hurt to verify the actual valve lift vs. the cam-card valve lift, too.
When I put Comp Cams roller-tip 1.6 rockers on my Father-In-Law's modified but mild-cam Pontiac 455, I had to grind the livin' pizz out of the pushrod holes to get clearance. The "book" said that the tops of the pushrod holes needed some grinding, but I had to grind all the way down.
Old 07-21-2021, 09:24 PM
Originally Posted by Steve C. View Post
Response was mixed but most said they still had to enlarge the pushrod holes using either Ford or Pontiac rockers above the 1.5 ratio. That's what I am trying to avoid.
I guess I will have to buy from a source with a "liberal return policy" and just try them out.
Old 07-22-2021, 06:08 AM
steve25 steve25 is offline
Try adding a lash cap and it may then clear the push rod hole depending on the lenght of the valves you have in the heads.
I forget if the 4.980" stock valve lenght of the late low comp heads get the needed clearance with a lash added, plus it's a easy try if you can borrow a cap from someone , or even just stuff.050"worth of feeler gauge in there to see how things change.
Old 07-22-2021, 09:16 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have a Crower 1.6 SBF that is way too short to fit.
Skip Fix
Old 07-22-2021, 09:18 AM
Formulajones's Avatar
Paul C would be the guy to ask. He has built several Pontiacs for customers using the Ford rockers and has explained many times what is needed to make it work. There was a reason he liked going this route better but I can't remember why.
https://youtu.be/XqEydRRRwqE
Old 07-22-2021, 09:28 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
[QUOTE=Schurkey;6266247]I have "small-block Ford" roller rockers on an Olds 455. They "fit" and "work", but because the valve angles are different (Olds has 7 degree valve angle, SBF has...20 degree valves (?)) the geometry isn't perfect.
Same here. "Close enough" for a mild street engine.
Less than optimum, like Kennedy's trip thru Dallas.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 07-22-2021, 09:45 AM
Lol!
Less then optimum=Yamamoto's flight to the Solomons!
Old 07-22-2021, 12:25 PM
[QUOTE=Mr Anonymous;6266384]
So you're saying that the rockers could cause a hole in my head?
Sorry, I couldn't resist the temptation.
Old 07-22-2021, 12:48 PM
The Neck first, then skull!
Old 07-22-2021, 12:51 PM
Skip Fix's Avatar
I can send you my Crower for a mock up. I bought a bunch of singles of various types to see what would work. For those not wanting to cut pusrod holes in head(ie already assembled) look at Crower's 0.090 offset BBC rockers with a lashcap and short pushrod.
Skip Fix
Old 07-24-2021, 01:20 AM
I appreciate the offer Skip, but Crowers are above my pay grade! I m looking into the 1.6's that FBPaul has on eBay as a candidate. They're abut $150 a set
Old 07-24-2021, 06:12 AM
So your 6X-8 heads are already on the motor?
If not, it’s a real simple 1/2 hour long job to just drill out the 8 intake push rod holes with a 1/2” drill bit to get a good amount of added clearance.
You need a decent size drill motor to power the 1/2” bit though!
Old 07-24-2021, 09:44 AM
64speed's Avatar
64speed 64speed is offline
I have 1.7 BBC on my 468
Old 07-24-2021, 09:46 AM
mrennie's Avatar
mrennie mrennie is offline
This may not be helpful info as this is not related to stock heads, but I tried Comp Ultra Magnum SBF 1.6 rockers on my 463 build using KRE D ports and the first version of the Stump Puller cam.
Spent a lot of time with an adjustable pushrod trying to get a decent pattern somewhere near the centre of the valve, and the only way to get the pattern halfass decent (width was "OK" but always too far to edge of valve) was with a pushrod length wayyy longer than ideal. The rocker geometry was just all wrong in this application using these Comp rockers. I have no idea if they are much different than other SBF rockers, but this was a waste of time and $$ for me.
Ended up going with 1.65 Crower Enduros and everything fell into place with what was a "normal" pushrod length for KRE's and the valve length they used. Pattern was nice and narrow, just slightly off centre.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 07-24-2021, 01:21 PM
Yes they are. I have been running the same 1.52 CompCams Magnum Rockers that came with the car (motor out and disassembled) when I bought it back in the late 80's. I have rebuilt the motor 2x since then and re-used the rockers after radiusing and smoothing the notches. Last time the heads were off was way before people were savvy about enlarging the pushrod holes.
I know the rockers aren't going to fail anytime soon based on experience, but I want to replace them with full rollers anyway and up the ratio via a bolt-on. If I take the heads off, you know what happens next ... credit card comes out and aluminum heads get purchased which I know I don't really need.
