Old 01-22-2023, 07:24 PM
grd777 grd777 is offline
Default correct trunk weatherstripping for my 72 formula
i have been looking at a lot of photos of finished cars and it seems the cars i am looking at all have different weathersriping then the one i purchased from firebird central
Old 01-22-2023, 09:41 PM
cnc's Avatar
cnc cnc is offline
George I ordered this on recommendations from Formulabruce. Now I sent this to friends in Michigan for pick up https://www.1aauto.com/1970-81-chevr...36/258266/1973
I think have some left over if I can find it Ill take a pic for ya same as u show for reference
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
The Following User Says Thank You to cnc For This Useful Post:
Old 01-22-2023, 09:44 PM
thanks , kind of looks like mine
Old 01-22-2023, 11:47 PM
Ramairnacho Ramairnacho is offline
Default Trunk seal
I bought a soft seal.brand one 30 years ago car sat that long and it's still good. Not sure if correct but it works.
Old 01-23-2023, 04:40 PM
Transamric's Avatar
My beef with a few brands of trunk W/S I've tried is that even though it may have the right cross section shape, it is too tough or firm so doesn't squish down enough. This doesn't allow the trunk lid to close fully allowing the dreaded 'gap-o-sis'!
What's been your experience with this brand?
Old 01-23-2023, 04:47 PM
yes i have that same issue to firm . firebird central has a better one for sale i will post a photo
Old 01-23-2023, 05:02 PM
maybe i will try this one
Old 01-23-2023, 06:50 PM
Transamric's Avatar
That looks pretty good. Who is that through?
Old 01-23-2023, 06:51 PM
firebird central
Old 01-23-2023, 08:09 PM
cnc's Avatar
cnc cnc is offline
This is what I used based on FB as mentioned here https://forums.maxperformanceinc.com...d.php?t=843620
Old 01-24-2023, 10:49 AM
78w72 78w72 is offline
i used the common metro brand trunk seals on 3 of my 2nd gen cars. cant say for sure if its a correct match to original but it works great, no issues with the trunk lid not closing right or having a gap & it seals water tight. just like door or window seals, when new they will take a couple weeks to compress & fit to the car but after a short time they conform nicely & doors, windows, trunk lid close as they should.
Old 01-24-2023, 02:02 PM
Formulabruce's Avatar
This is the Only brand that has the exact shape and size of the factory seal. A1A auto has a video on their you tube site of the owner installing it CORRECTLY on a Catalina.
One key is that it's not TOO thick, but seals. Also stays put if you install correctly. 90% of other brands do NOT sit in the channel correctly.
These also pass the dollar bill test evenly.
Year or so ago my buddy and I tried a bunch on his 74 and his 70, then on my 72 with same results. With correct thickness and install its easier to tell if your seal channel is bent down or up and or leaks.
