#41
Thanks Paul. Ya the converter went in perfectly. I somehow think it's a bit on the big side from what I'd like to see. It's a 245 mm converter. I'm hoping it flashes to around 5500. My current one flashes to 5000 which seems to cause the engine to be lazy off the line. https://www.coanracing.com/coa-20440...per-sprag.html
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
#42
Did you get the ARP bolts in? Did it give you clearance?
