Old 02-16-2023, 03:36 PM
64Lemans 64Lemans is offline
Default Paint Recommendations
Hi.
I am looking to touch up the following:
1. The glove compartment door (metal)
2. The arm rest area (top area along the window strip if you will....on the front driver door) (metal)
3. Rear window trim (typically comes in standard black) (plastic)
My interior is Saddle Bronze. Does anybody recommend any particular paints / touch up / spray, tips/tricks .etc.. to accomplish this?
Thank you.
Old 02-16-2023, 07:38 PM
Jeff Hamlin's Avatar
FWIW;
I've used these guys on a few projects both vintage and newer and they were spot-on each time.
https://www.automotivetouchup.com/
Old 02-27-2023, 07:10 PM
geeteeohguy's Avatar
40 years ago I had a local paint store mix up the correct medium blue color code in 60% gloss and also in flat for the dash and door tops of my '65. It came in spray bombs and worked great. Now, all these years later, it looks like original, but matches the original interior. IIRC it was lacquer at that time.
Jeff
Old 02-27-2023, 09:23 PM
jamesq's Avatar
jamesq jamesq is offline
Originally Posted by Jeff Hamlin View Post
FWIW;
x2 on above, they will sell you spray cans as well!
James Q
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
