Old 05-02-2023, 09:44 AM
JUDGEMAN70 JUDGEMAN70 is offline
Default Correct red oxide epoxy primer
Who Where would I get the correct red oxide epoxy primer for my 70 GTO that matches what the factory used? I was told PPG discontinued it. Thanks
Old 05-02-2023, 10:02 AM
Trevor78 Trevor78 is offline
Are you referring to DP74LF, which was a PPG product?
The Following User Says Thank You to Trevor78 For This Useful Post:
Old 05-02-2023, 10:25 AM
unruhjonny's Avatar
is this the dip tank red primer?
I think I found a dead ringer, but it's really hard to get;
https://nlsproducts.ca/shop/products/rust-destroyer
It's manufactured in Ontario (Canada) but it seems like retailers that carry it outside of Ontario are few and far between.
1970 Formula 400
Old 05-02-2023, 11:16 AM
No more DP primers used here. SPI epoxy is avail locally & what I've been buying.
For correct GM shade of red oxide primer, will take mixing SPI red oxide (which is too red) w some black SPI epoxy primer.
Old 05-02-2023, 10:27 PM
400 4spd.'s Avatar
The DPLF74 is marketed as “obsolete” through PPG jobbers. However, some jobbers still have stock. Mine had a quart on the shelf that I bought today “just because”. Last year they located two gallons for me that I have set aside for the proper restoration candidate.
Old 05-05-2023, 09:13 AM
found some DPLF74. My paint store guy found some at a different store so still some floating around out there
Old 05-05-2023, 09:27 AM
MUSLCAH MUSLCAH is offline
What was the correct primer / sealer used aftah ....the red oxide ?
