Old 12-09-2022, 12:34 AM
KSZR KSZR is offline
Originally Posted by Mcronk View Post
I took a look when they held the downpipes up to the manifold. Not only does the lip need to be clearanced for the bolts but the bell is too large to seat on the manifold. So it needs to be ground around the entire circumference of the head pipe. I am going to take about 3/16" off around entire lip. I will see if I can unbolt the headpipe and move it enough to slip the new downpipe up on the collector for fit.
After some advice from Pypes I ground mine down with a 4" grinder set flat across it. Cleared the bolts. Then he said to magic marker the inside of the bell. Bolt to the manifold then remove and see where it rubbed the marker off. Needs to rub all the way around to seal. Had to grind several times to finally do this. Seals good now.
Was a pain.
