Herb Adams cast aluminum oil pan
Selling a rare cast aluminum Herb Adams oil pan. I bought it for my engine build but it will not clear the main caps on my aftermarket block. No issues with it, doesn’t appear to have ever been used. Asking $400.
That is bad ass!
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
Where is the pan located?
Aluminum is easy to modify. You could weld in some little "bump outs". Cool pan though!
There is FireAm group on Facebook might add it there some of those guys are hard core old Herb Adams stuff.
Got the baffle to seal it too! Smaller rear sump helped clear his 180 degree headers!
PM to you 70 bonne
Tom Vaught
PM replied to Tom. Yea I had thought about modifying it but I didn’t want to cut it up since it isn’t a common piece.
Probably would be a shame to cut on.
I will modify the pan for the aluminum All Pontiac Block so that only an expert would know the extra clearance for the main caps is not as made by Herb himself.
Last Time I saw Herb he was back in Michigan doing engineering for a company in the state and still building his Herb Adams designed "Contessa" sports car. Tom V.
70 bonne, please post that the Herb Adams Oil Pan is no longer for sale.
Tom Vaught
There is someone that has been restoring his old Silverbird road race car. It still looks pretty bad!
Yes Skip. I was told that a couple of years ago "Dave" a co-worker at my job and a Pontiac Nut for many years (who bought the Silver Bird Race car from Herb) sold the car to a third owner who is now in the process of restoring the car. This is the real deal car.
So it may be shown again in the future in a magazine. I sold Dave a Raw 366 Forged Crankshaft as a back-up if the original crank was ever hurt bad. NOT LIKELY. Tom V.
Oil pan is sold.
Dang. I missed out badly, I don't know how I missed this back in 2020, I was hunting one since 2018. Still in desperate need for one for my 1979 Fire Am if anyone else happens to have one for sale.
In the early 90's, had a never used Herb VSE pan & a set of Herb 180 degree headers which were designed to fit w the pan. The header sections went together like a puzzle, the sections had not been welded together yet. Have several pictures of the ready to be welded headers mounted on a Dport engine, if anyone is trying to recreate a set, will dig out the pics.
Forwarded the 3 pics to Jeff, hopefully he can post them for me later today.
If somebody that has a VSE pan could publish the dimensions, a dimensionally equivalent pan could be fabricated.....to use with 180 degree headers.
Just a thought.... Eric
The Following User Says Thank You to Elarson For This Useful Post: | ||
They very likely could, I mean Jim Haller has purchased most of VSE's equipment and may even be able to reproduce new ones again, but it's like how someone restoring a W72 would want to chase a period original carb. I'd like to try nab an original, or maybe see if the Adams' will be interested in reproducing one. I could just buy the new Pontiac Moroso oil pans, but where's the fun in that
Pic is from ole pinion head posting for him
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
