Old 10-09-2022, 12:16 AM
53Convertible 53Convertible is offline
Default Convertible top Help????
I see where automatic transmission fluid is used in new electro-hydraulic systems, for convertible tops, is this the same for 1953 systems? The top is down now, I have pushed and pulled on the switch on the dash and I hear the pump running but no top movement. I suspect it is low on fluid but I need to know what to put in it if this is the case.
Old 10-09-2022, 08:20 AM
Tim john Tim john is offline
Typically brake fluid or ATF was used. Check for color of fluid as an indicator.
Tim john---
