Old 12-11-2022, 03:08 PM
Indy1k Indy1k is offline
Default 65 GTO Rotary Valve vacuum Tube Spider
My 65 GTO has factory air. Restoring the car and would like to replace the A/C rotary valve vacuum tubing spider which is an assembly comprised of a multiport fitting and various color coded vaccum tubes coming off.
Do anyone know if there is an OEM part # and does anyone make this assembly?
Thanks in advance
Kevin
65 GTO 2Dr. Hardtop, 4spd.
Old 12-11-2022, 06:42 PM
Jeff Hamlin's Avatar
I was looking for my '66 years back and lucked out with an NOS part.
Don't know if anything is available in the aftermarket.
This is from the '66 Edition Parts Book, I can't tell you if it was ever issued a superseded part number later on.
Name:	65-66 AC PTS BK PG 1X.jpg
ID:	603399   Click image for larger version
Name:	65-66 AC PTS BK PG 2X.jpg
ID:	603400   Click image for larger version
Name:	65-66 AC PTS BK PG 3X.jpg
Old 12-12-2022, 01:43 PM
Thanks Jeff,
The pages are for 65-66 so it should be the same.
I have the same book, So I will see if I can find a part number for it.
Happy Holidays
Kevin
Old 12-12-2022, 02:31 PM
wbnapier wbnapier is offline
Could you guys post up a link for these parts books? Thank you.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 12-12-2022, 03:10 PM
I bought this disk many years ago on Ebay. Dont remember from who. If you cannot find it, let me know and I could send you a copy if it isnt copy protected.
It is all in PDF format.
Kevin
Old 12-12-2022, 08:43 PM
That would be awesome if you could email it or share it!
wbnapier@yahoo.com
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
