Old 04-08-2023, 03:32 PM
Default 1955 steering wheel - removal?
How does the Deluxe steering wheel come off on a 1955 Chieftain? I don't want to break the chrome horn ring trying to remove it. Thanks.
Old 04-08-2023, 09:23 PM
fyrffytr1's Avatar
Do you twist the horn button counterclockwise until it pops off revealing screws that hold the trim ring on? Or The horn button is held on by spring clips on each side even with the trim cross bar. Use a trim pry bar (screw driver) to gently pry the button off.
Old 04-08-2023, 09:35 PM
WQ59B WQ59B is offline
'55 shop manual ~
Name:	Screenshot 2023-04-08 at 9.33.14 PM.jpg
Old 04-09-2023, 12:12 AM
Thanks. Do you have Figure 9-6 showing tool J-3044?
Old 04-09-2023, 01:10 PM
Whole shop manual is online:
http://www.pontiacsafari.com/55/ShopManual/index.html
J-3044 ~
Name:	Screenshot 2023-04-09 at 1.09.34 PM.png
Old 04-09-2023, 01:24 PM
fyrffytr1's Avatar
It is a two bolt puller. You can use just about any aftermarket puller. This is what the block part looks like:
https://www.ebay.com/itm/114738206461
And this one would work. You can probably get it at just about any parts store.
https://www.amazon.com/Lisle-45000-S...=15708901&th=1
Old 04-09-2023, 01:25 PM
Thanks. Looks like an ordinary wheel puller. I was afraid it was the old type puller. I haven't seen one of those since the 1960's.
