Correct red oxide epoxy primer
Who Where would I get the correct red oxide epoxy primer for my 70 GTO that matches what the factory used? I was told PPG discontinued it. Thanks
Are you referring to DP74LF, which was a PPG product?
The Following User Says Thank You to Trevor78 For This Useful Post: | ||
is this the dip tank red primer?
I think I found a dead ringer, but it's really hard to get; https://nlsproducts.ca/shop/products/rust-destroyer It's manufactured in Ontario (Canada) but it seems like retailers that carry it outside of Ontario are few and far between.
No more DP primers used here. SPI epoxy is avail locally & what I've been buying.
For correct GM shade of red oxide primer, will take mixing SPI red oxide (which is too red) w some black SPI epoxy primer.
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
The DPLF74 is marketed as “obsolete” through PPG jobbers. However, some jobbers still have stock. Mine had a quart on the shelf that I bought today “just because”. Last year they located two gallons for me that I have set aside for the proper restoration candidate.
found some DPLF74. My paint store guy found some at a different store so still some floating around out there
What was the correct primer / sealer used aftah ....the red oxide ?
Thread Tools | |
Display Modes | |
