Old 05-24-2023, 07:45 PM
SRR's Avatar
SRR SRR is offline
Default TH400 ID? Weird filter set up?
I'm trying to ID this TH400, far as I can tell it's Chevy 1968 but what is up with that filter and pick-up tube?
ID:	613151   Click image for larger version
ID:	613152   Click image for larger version
ID:	613153   Click image for larger version
― Calvin Coolidge
Old 05-24-2023, 07:57 PM
That's a TH350 filter. B&M used to offer a kit to adapt that style filter, know I installed a few in the early 80's along with deep GM TH400 pans.
Old 05-24-2023, 08:04 PM
SRR's Avatar
SRR SRR is offline
Default So...
Is this the one I need?
Name:	Screenshot 2023-05-24 at 17-03-07 Duralast Automatic Transmission Filter TF601.png
― Calvin Coolidge
Old 05-24-2023, 08:24 PM
242177P's Avatar
242177P 242177P is offline
That's the early style, early 67s still used them. Later units use the super-common broiler pan style.
The Following 3 Users Say Thank You to 242177P For This Useful Post:
Old 05-24-2023, 09:16 PM
stevep's Avatar
stevep stevep is offline
That is a Torqueflite filter and it will be fine
The Following User Says Thank You to stevep For This Useful Post:
Old 05-25-2023, 06:26 AM
steve25 steve25 is offline
I don't like that long pickup tube deal, as it likely does not stay primed well like a stock filter set up does.
I would be thinking about getting a stock pan and run a stock filter.
The stock filter has a ton more surface area also!
Old 05-25-2023, 07:10 AM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
1990 SS 454 Chevy trucks used an extended tube and a spacer for a deep pan/stock filter. Maybe there is something like that you can use.
Old 09-17-2023, 02:41 PM
SRR's Avatar
SRR SRR is offline
Default Went this route
This:
ID:	620143   Click image for larger version
― Calvin Coolidge
Old 09-17-2023, 06:16 PM
gto4ben gto4ben is offline
Ah yes. The 5579822 1st type filter for early TH400. Just make sure the pan is also 1st type with the dimple and recess to space the pickup away from the stock pan.
The Following 2 Users Say Thank You to gto4ben For This Useful Post:
Old 09-17-2023, 10:04 PM
chuckies76ta's Avatar
Recommend as the Th400 filter of choice with brass screen. # 34010B High flow.
Old 09-18-2023, 01:05 AM
sdbob sdbob is offline
I too like the pan type filter with mesh screening.i avoid the pan type with paper like filter. I learned sometimes the paper filter will not 'suck' the tranny fluid.
Old 09-18-2023, 12:51 PM
Old Goat Racer's Avatar
While on the subject, can a 65 400 turbo use the later style filter ?
Everybody knows somthin.
Nobody knows everything !
Old 09-18-2023, 01:16 PM
242177P's Avatar
IIRC, drill and tap the valvebody. Once it has
that mounting hole it's straightforward. Or
use a later valvebody.
Old 09-18-2023, 05:02 PM
Sirrotica's Avatar
Swapping valve bodies in T 400s can be dicey, although they look similar there are subtle differences in the OEM valve bodies that aeren't always compatible between other applications.
My opinion would be to drill the valve body you have, because I have seen the problems swapping them can create.
I've used the early filter setups in high performance applications without any troubles, Just double O ringed the tube that goes into the case to safeguard against sucking air at the connection point, FWIW.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 2 Users Say Thank You to Sirrotica For This Useful Post:
