Seat bolt stripped, advice?
Front bucket seat bolt hole is stripped. I tried to chase it with a trap but it's too far gone. Go from 5/16 to 7/16?
Sent from my SM-G860P using Tapatalk
http://www.outlawpontiacdragseries.com |
Happened to me years ago. I run a nut and bolt no sweat. I remove the seat infrequently, so it doesn't really cause problems. Reaching below with one wrench at the same time as wrenching from above is easy.
Helicoil
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue Last edited by 68bird400HO; 11-15-2017 at 12:51 AM. |
So you drilled through the floor?
You don’t have to drill through the floor, seat belt floor nuts are already open to the exterior
My Break Away Squad 1969 Fbird (Base, 350, 400HO & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
You don't need to drill out the stripped hole, but probably easier overall. Use a longer bolt & fit a nut...
How about a rivet nut?
68 400 HO 4sp Convertible Firebird400HO.com My 68 firebird 400 HO convertible Restoration Gallery |
I like the rivnut idea. Pretty easy to install. If you want it to look correct, you could use a time-sert . Recently I used them to fix a bad thread in a rear end bolt hole and a thread in my aluminum Muncie case.
Expensive, but super strong. As a test, I took an aluminum bar, drilled and tapped a hole in it, then did a time-sert with the same internal thread size. I torqued each one until they failed and the time-sert actually took more torque. Pretty impressive. |
I think JR is referring to the actual seat track to floor bolt, not seatbelt. Right?
Seat track to floor. Rear one. Near the tunnel. Been work on my 2005 gto, so back to this soon.
