68 Firebird 4-speed Shifter & Linkage I.D.
Came across this shifter today... Supposed to be from a '68 Firebird.
What do the stamped numbers on the shifter denote...date code? "11 7B2" Does the linkage appear to be '68 Firebird? What's the difference between Firebird & Camaro and '69 Firebird? Thanks!
John '68 Firebird Ram Air 4-spd Conv. John 14:6 Semper Fi |
After doing some digging here and on the CRG site, I believe I've answered some of my above questions...
- Date code on '68 and very early '69 shifters... 11 7B2 = Nov. 1967 (B2 is an internal batch number) - '68-'69 Firebird and '69 Camaro used the same Hurst shifter. - Not sure about Linkage... '68-'69 Firebird same? '69 Camaro had different linkage depending on engine; any shared with Firebird?
That's a 68 Firebird all right. Even has the correct reverse lever.
68 400 HO 4sp Convertible Firebird400HO.com My 68 firebird 400 HO convertible Restoration Gallery |
if you want to use the reproduction 69 Camaro linkage, you can change the levers or add an adapter they make so you can use the 69 levers on the 68. The reverse lever is different for 68 Firebird. It was used only for 68 Firebird.
Also, you will need the mount bracket to mount the shifter. The 69 Camaro hurst shifter bracket is the same.
