[QUOTE=25stevem;6332780]See if the dyno your taking the motor to can measure the specific gravity of the fuel you swap to once you get a baseline pull done.
I will inquire, but been told Joey Arrington has one of the most up-to-date dyno shop in the area. |
Kind of like Tom one of my local Pontiac buddies had a Canadian Pontiac Acadian he had a 377 SBC(they came with Chevy motors but his was a 6 banger originally) in it aluminum heads. Ran on pump gas. Ran out at track and put race gas in it as all they had and ran 0.3 sec slower.
[QUOTE=Dragncar;6332806]. Do you know how much overlap the cam has ?
I Dragncar, after reviewing the cam card, it has a reading I don't understand It's been my thoughts that you add IVO-BTDC # with the EVC -ATDC # to get overlap. And if I'm understanding this correctly , it's giving me 176,* of overlap, which can't be right. |
I cam up with 64 degrees of overlap.. using the Adv dur @.020"
Thanks, guess I was using the. 050 numbers?
575HP
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
[QUOTE=68WarDog;6332847]
You add the intake opening point and the exhaust closing point to get the overlap, like you said. I think you got confused with the exhaust centerline (114) typed a bit farther to the right. |
