Cam Bearings gone bad? Not Pontiac
Don't have much experience with high mileage engines so bear with me. A few years back my brothers and I bought a 1998 Chevy C3500 Dually with 163K miles on a 5.7 L31 gas engine that we hoped to use for several more years as a reliable tow truck for hauling small cattle loads to market. Truck had been auctioned from the public works dept of a local municipality so we felt good about maintenance record & price. Fast forward to last year, we've only added 5K miles and oil pressure gauge starts to read very low pressure at idle. Older brother takes to local small town Chevy house, they keep for almost a week, report they checked bottom end and oil pump, suspect cam bearings need to replaced.
Not familiar at all with SBC from that vintage, but internet seems to agree cam bearings can be an issue at that mileage level. Any opinions on whether it's worth a rebuild, or reman engine swap, or cut and run now? Additional detail, 4L80e trans, 4.10 rear end, six new tires (less than 2k miles on all six). Appreciate any and all advice. Mike Pearson
Fort Worth/Dallas TX area 1966 GTO Fontaine Blue 389 CID Carter AFB Muncie 4 speed (orginally an automatic car) |
I'd double check the pressure with a mechanical gauge. GM sending units from that era like to act up.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
The Following User Says Thank You to 72projectbird For This Useful Post: | ||
Any engine thst is presently driving a 4L80 might be a good engine to maintain,
I have a '90 silverado with the 5.7L TBI engine, it had a new oil pump installed before I bought it at around 200K. It has 295K now. Engine never opened, aside from that oil pump job, to best of my knowledge. Still runs, tired, but am hoping to get it into the 315k range before engine comes out. Running thinner oil (0W, 5W) could also give low oil pressure readings.
Would have figured a 3500 chassis would have had either a 7.4L or a Diesel. Last edited by newmexguy; 08-01-2022 at 08:10 AM. |
As 72 said I'd ck with 'known' good mechanical gauge. Even 2nd gauge just to be sure. This day and age 'junk' from overseas just isn't what products use to be.
As stated, verify the pressure with another gauge. If faulty, how low is the pressure? All you need is 10psi for every 1000 rpm. Consider running 15/40 oil.
You can get a GM crate engine with a warranty for under 5k for your rig, and it would be money well spent if you don't want the hassle of a rebuild.
Jeff |
Also looking hard at the "crate engine" option. Seems there are some attractive options, but several say they are only "calibrated" for up to the C2500 powertrain, don't really understand what that means. Thanks for all the input so far, really appreciate the responses.
