Old 04-20-2022, 05:24 PM
grandam1979 grandam1979 is offline
Default 1964 GTO body bushings
I’m working on a 64 that has original body bushing. You can see that they are very rotted and sunk. My question is how thick is a new bushing for this car? I’m thinking the body is a good 1/2” plus closer to the frame than it should be. Thanks
Old 04-20-2022, 06:08 PM
Dick Boneske's Avatar
Buy the kit from our host, Ames Performance, and you'll have the correct bushings. Who cares how thick they are if you're replacing them with new ones from a reputable source.?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 04-20-2022, 07:03 PM
I do thanks anyway.
Old 04-21-2022, 09:24 AM
69hardtop 69hardtop is offline
Originally Posted by grandam1979 View Post
I do thanks anyway.
I measured new ones for you at:
.73 for the flat bushing
.85 for the stepped bushing
Rubber measurement only not including the steel spacer. I believe I got this kit from Inline Tube (guessing maybe a common supplier) My old ones (also on a 64) were squished down pretty flat
Old 04-21-2022, 03:58 PM
Thanks a lot that helps.
