Old 07-10-2022, 09:38 AM
jhein's Avatar
jhein jhein is offline
Default Progress - Machine work is done
Ready for assembly this week, then dyno. The block is a thing of beauty.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following 2 Users Say Thank You to jhein For This Useful Post:
Old 07-10-2022, 10:02 AM
PAUL K's Avatar
PAUL K PAUL K is online now
Nice!
Go fast, see Elvis!
Old 07-10-2022, 10:17 AM
25stevem's Avatar
25stevem 25stevem is offline
Sweet!!
Ya hate to hide it all with oil pan, heads and intake I know!
If this is a IA block and you have never used one before, note that the front lower passenger head bolt hole may still go into the water jacket and is not blind.
They may have changed this with later blocks, but it still pays to check.
I do stuff for reasons.
The Following User Says Thank You to 25stevem For This Useful Post:
Old 07-10-2022, 02:56 PM
joes455 joes455 is offline
Don't understand,brand new block that requires machine work ouch
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 07-10-2022, 04:29 PM
jhein's Avatar
The block came with a 4.145 bore and it had to go to 4.185. Also line honed, decked, balanced. It also came dry decked so needed that too. The heads are new E-heads but needed some cleaning up and new springs. That's it I think.
Old 07-10-2022, 07:48 PM
AG's Avatar
AG AG is offline
New blocks need complete machining, B/H, deck and usually the mains. That's a small bore.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
The Following 2 Users Say Thank You to AG For This Useful Post:
Old 07-12-2022, 11:08 AM
jhein's Avatar
Originally Posted by 25stevem View Post
Sweet!!
I talked to Frank at All Pontiac and he said that was corrected a while back. But thanks for the heads up.
