A body differential ear bushings
I am changing out my 8.2 for a new diff. I currently have the Detroit Speed urethane bushings in the upper ears. Detroit Speed does not seem to sell them as a separate item, so I am looking for an alternative and looking for suggestions. I saw that RideTech offers their “R joint” and wondering if anyone had tried it. I also suspect that the urethane bushings could be causing some of the noises I hear in the back, but then I have DS stuff all around. Any suggestions will be appreciated. Thank you.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
They hold up just fine. Put them on last year and couldnt be happier
72 Luxury Lemans nicely optioned |
Ride a little rough
Ridetech is excellent smooth ride
For a long time the general consensus was to go with stock rubber bushings on the diff. The polyurethane bushings bind up the action of upper control arms.
Triple Black 1971 GTO |
The reason I switched to the Roto-Joints is that I don't believe the replacement rubber compounds are the same as the 50 year old originals I pulled out. I didn't want Poly so the Roto-Joint seemed like a reasonable alternative. I didn't want to go back and replace the rubber bushings after 5 years or so
I replaced the bushings in the upper arm with rubber so that should isolate the harshness, if any, of the Roto.
More in the front than in the back but I have found the ride to be a lot more “stiff” than most people are used to.
I had all 4 roto joints in uppers. Destroyed the ones in the diff. Talked to UMI and they recommended i change out the diff joints to urethane and leave the other uppers rotos. I did that early last year. All good so far lots of launches at the strip.
[SIGPIC] Steve |
I contacted UMI and they suggested I use the urethane for best ride. Their customer service said the roto joints were for uneven road surfaces.
