block bolt holes
started painting block before building last night and noticed bolt holes dont match the motor in car this is a newer 76 block and my car is 68 bird
does anybody here have diminsions on old block verses new block so i could make adapters ? |
I think starting in 1976 they eliminated two extra motor mount holes that would have allowed installation in your '68.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following User Says Thank You to AG For This Useful Post: | ||
Butler sells adapters as do others.https://butlerperformance.com/i-2445...tegory:1393557
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post: | ||
Block side shot.
I do stuff for reasons. |
Know little about 1976 blocks except that the 455 engine was gone in 1977 and
the 1976 block is supposedly not very strong. If Pontiac Dude was still posting he could tell you the whole skinny. Tom V.
Here’s all the bolts holes needed to have it go into any body and any year.
I've used the block adapters, they work fine.
Not sure where i bought them, might have been yearone or classic ind.
birds, goats and a few outliers |
would you get measurements off for me
I can't, that motor in my picture is in a car right now.
That adapter from Butler is what you need!
This was from HPP magazine (I think):
#1 and 4 are the late block mount holes. (don't need the #3 hole) #2 and 5 should be the early motor mount holes. I have never double-checked these, so take it with a grain of salt. There was a thread (or more) on this conversion also on PY.
The Following User Says Thank You to johnta1 For This Useful Post: | ||
hole pattern
Looks like the article may have switched a couple digits?
(8.61 instead of 8.16?) The articles measurement from 2-3 and 3-4 were unnecessary for your needs. Too bad they didn't provide the inline holes like your pic. EDIT: Looking at the block pic I posted, it appears the article also had the bolt holes numbered differently to what they measured in the article. Their measurements are roughly the same as your pic (except 8.16" instead of 8.61 in article) Their hole numbers should be 2 to 4 (3.65") and 4 to 5 (1.45") Glad you found that pic.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates Last edited by johnta1; 07-28-2022 at 11:14 AM. |
On your block you have one of the bosses necessary to drill and tap for the motor mount, (red arrow). Red circle is where the forward mount hole would be, but no boss there. If it were me I’d tap that rear bolt hole and use it in conjunction with the adapter strap for extra strength.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
Posting this as correction (for posterity):
BTW, in my notes I had that someone on PY said the 2 to 5 measurement was 5.115". (OP's pic has 5.1")
i drew this up in cad and laser cut and fits perfect i did drill and tap the 1 boss on block instead of grinding it off |
No offense taken. My info wasn't clear and trying to correct it.
Yours is a good pic of the holes/measurement.
Am I the only one here who gets puckered looking at those core plugs? They look like they were installed by beating a punch against the center of the plug, instead of being pressed on the outer rim.
Unless someone showed the installer how to do the job correctly, this is FAR more common than most think, on engine builds.
Tom V.
The Following User Says Thank You to jwhit For This Useful Post: | ||
