Old 05-12-2022, 11:32 PM
bhill86's Avatar
bhill86 bhill86 is offline
Yamabond or Hondabond, from your respective local Yamaha or Honda motorcycle dealer, are good alternatives to Hylomar. You can probably get them online from Amazon or other sources as well.
I saw Hylomar on Amazon actually
Originally Posted by NeighborsComplaint View Post
About a tenth of a thousandth.
Thanks, that helps. That said, would I be correct in my assumption that this pic of the rod journal I posted earlier with that score on it should be polished at least? It can be lightly felt with my fingernail. I haven’t checked the other journals yet. The crank is .030 under already and clearances from the last builder were .0018-.0019 on the rods, .0021, .0019, .023 .023, .023 on the mains.
I’m an amateur at best at this but those seemed a bit tight however I was also afraid polishing would open them too much and if I read correctly another .010 off will make it difficult to find bearings. Not to mention the .030 under sets I bought just showed up today.
Assuming that score is the worst of it and can be polished, I’m thinking I should be safe?
1977 Trans Am 400/4speed (swap)
Brian
  #102
Old 05-13-2022, 12:43 AM
Dragncar Dragncar is offline
Originally Posted by bhill86 View Post
So safe max would be up to 3/4”?
Going back to the filter housing real quick, this engine is a 69 with the 90° filter housing which also has the provision for the sensor perpendicular to the block which does not allow installation in my f body. Someone before me drilled and tapped the side of it so the sensor could be located the same as the 120°/tilted filter housing. That wouldn’t cause an inaccurate pressure reading would it?
The people at Steffs told me 1/4" with no gasket so you end up at 3/8" is where you want to be. 1/2" max.
No way I would run a pickup 3/4" off the pan floor.
  #103
Old 05-13-2022, 06:04 AM
25stevem's Avatar
25stevem 25stevem is offline
Have the Crank polished since you cant do it right on you own unless you can rig up a way to spin it and also spin it in the right direction.
After that any light scratches that might be left on the Crank journal will be low spots and not harm anything.
I do stuff for reasons.
  #104
Old 05-13-2022, 04:52 PM
bhill86's Avatar
Will do. I called a few machine shops today and hope to have time Sunday to pull the crank and drop it off Monday.
Thanks for the info
Brian
  #105
Old 05-18-2022, 08:28 PM
bhill86's Avatar
Haven’t had a lot of time lately but I did get the cam sprocket and timing chain off today. It was tighter than I expected. The crank sprocket moved enough to get the cam gear off but I CANNOT get it if the crank snout. Figured I’d leave it on and the machine shop can remove it if needed when I have it polished.
Should they be that tight though? Videos I’ve seen seem to show both slip on essentially.
Also, a small win, when I removed my water pump I discovered it was a stamped impeller and there was a lot of space between it and the backing plate. New pump has a cast impeller. Hoping this improves my cooling. Never overheated per se but temp would increase on the highway a little and at idle with A/C on. Hoping this helps both.
Brian
  #106
Old 06-09-2022, 01:02 PM
bhill86's Avatar
Quick question….
Installing my oil pump. Actually, attached the pickup and am measuring for proper height. The screen end of the pickup is angled and appears to be brazed so it can’t be altered. I assume that’s ok and perhaps on purpose. But when it comes to measuring the depth of the pickup, I know 3/8-1/2” is recommended but with the angle of the pickup, is there a preferred place to measure? Do you measure at the lowest point? Highest? Center-ish and split the difference?
Maybe over thinking it but don’t want to discover a mistake once everything is back together.
ID:	592514   Click image for larger version
Brian
  #107
Old 06-09-2022, 01:24 PM
tom s tom s is offline
Turn the engine over,put a ball of tin foil on the pump pickup and put the pan down on it.You will know for sure of how close.Tom
The Following User Says Thank You to tom s For This Useful Post:
  #108
Old 06-09-2022, 01:59 PM
bhill86's Avatar
I’ve seen the foil method suggested which I’m not opposed to doing but that will still leave me with a “thicker” side and “thinner” side no? Due to the angle of the pickup.
Brian
  #109
Old 06-09-2022, 03:49 PM
25stevem's Avatar
Your fretting over literally nothing here!
A 3/4” ID tube has a open area of .4417 sq inches and even the type of pump pick up that has a half closed off face has over 3 times that amount of sq inches for surface area!
  #110
Old 06-09-2022, 06:41 PM
bhill86's Avatar
I wouldn’t say I’m fretting over anything. Was just trying to verify the correct way to measure and was curious about the angle of the pickup. At this point, I’ll set the lowest part of the pickup around 3/8 and move on.
Brian
The Following User Says Thank You to bhill86 For This Useful Post:
  #111
Old 06-21-2022, 04:46 PM
bhill86's Avatar
Getting things back together. Does the throw out bearing, pilot bushing and/or trans input shaft splines get any kind of lube or should they be dry? Clutch kit came with some lube specified for the input shaft splines but I couldn’t find a definitive answer.
Thanks in advance.
Brian
  #112
Old 06-22-2022, 08:11 AM
chuckies76ta's Avatar
Brian: The Throw out bearing should be pre-greased if new, if not get a new one. The throw out bearings are designed to self center also. The pilot bushing could have a very minimum coating of grease. I believe some of the brass bushings are oil impregnated. Same for input shaft. Very very minimum grease. Reason being as this equipment turns it will fling oil or grease off and possible contact on clutch which is bad. Make sure to brake clean flywheel and pressure plate disc. You can also put a tiny dab of grease on the clutch fork where the throw out bearing contacts and the pivot ball.
  #113
Old 06-22-2022, 03:52 PM
bhill86's Avatar
Appreciate it. Got it all back together today and engine reinstalled. Hoping to have time the next few days to get it buttoned up and started for the first time. I should’ve specified what I meant when I asked about the TO bearing. I meant where it rides not the bearing itself. Thank you though.
Brian
  #114
Old 06-23-2022, 07:39 AM
There will already be grease in the bearing. If your talking about where the bearing surface rides on the pressure plate, I say no. None on the back side also. Only place minimum grease is on bearing retainer. The smooth shaft side where the bearing rides. I believe it's called the Steel bearing retainer. Here is a pic of the retainer. https://www.ebay.com/itm/202972761657 The bearing rides back and forth on this retainer.
A new bearing usually has a little channel inside that holds a bit of grease in it. I'm sorry as I'm not the best at explaining this.
So only place that there is a bit of grease is on the inside of the bearing where the bearing moves back and forth on that tranny bearing shaft.
  #115
Old 06-23-2022, 08:57 AM
bhill86's Avatar
No it helps and I think I’m in good shape with it. Thank you again
Brian
  #116
Old 07-08-2022, 06:35 PM
bhill86's Avatar
I figured even though my approach may not have been what everyone else would’ve done I’d give an update now that I have some miles on my engine. I ended up pulling the crank, had it polished, replaced the main and rod bearings (measured as best I could), new 60 psi pump, set the pickup higher than the last one and gave it a shot.
My lowest pressure I’ve seen on 90°+ days is 12-13psi at idle after a highway jaunt. 15w40 oil. More typical is15- 18ish psi. Like today for example, around 80° or a bit warmer today and I was seeing 18psi. I’m thinking that’s good enough for now at least. Maybe the cam bearings are clearanced a bit more or something but I still feel it’s improvement especially since ambient temps were in the 50s and low 60s before I pulled it and only showing 8-10psi.
Ideal? Maybe not but again, better than it was and probably manageable till I do a legitimate rebuild someday. Thank you to all that responded and offered advice.
Only issue I’m facing is clutch chatter but I think I’m going to start a new thread on that.
Brian
  #117
Old 07-08-2022, 07:58 PM
25stevem's Avatar
I had a 400 that during a very cold winter had some crap keep the check ball partially unseated.
When fully warmed up it only had enough oil pressure to just about keep the oil pressure light from flickering.
The max oil pressure it had above 2500 rpm was 35.
I drove the car like that thru 4 months of winter and many times beating it on it in forgetfulness that it had low pressure.
Come spring I pulled the motor out to find that the bearings looked like what you would expect from a motor with the mileage it had on it.
Number two rod bearing was the only one showing some very very light signs of running hot .
Your motor should hold up fine for you especially with todays oil compared to what I was running back in 78.
  #118
Old 07-08-2022, 08:08 PM
bhill86's Avatar
Hope so. I plan to monitor the filter in the meantime. Thanks for your input.
Brian
  #119
Old 07-09-2022, 06:11 AM
25stevem's Avatar
One thing I would suggest to you is to monitor/ note how many ft lbs it takes to bar the motor over with the plugs out at room temp, even if you need to buy the type of torque wrench needed.
Besides confirming that no crap is showing up in your oil it’s very reassuring to know that as the miles pile on that nothing is adding friction to the rotating assembly.
  #120
Old 07-09-2022, 08:49 AM
Half-Inch Stud's Avatar
Didnt read these 6-pages. Did the conclusion reach the clapped-out cam bearing being the cause?
