Old 02-24-2018, 09:32 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Default Will a 72 chevelle bench fit a 67 Tempest.
Got a line on a really good looking 72. It’s close and if it fits, I’ll dye and throw it in until I can reupholster my original.
Thanks.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 02-24-2018, 09:40 PM
Chris65LeMans's Avatar
I’d be surprised if it bolted right in.
Old 02-24-2018, 11:03 PM
gtospieg gtospieg is offline
It may not "bolt right in" but I'm pretty sure you can make it fit. Have you measured the width of yours to compare to the Chevy? You should also measure the width of the seat tracks where they mount to the floor. Maybe your seat tracks would bolt to the Chevy seat if they are different. It's at least worth going to look at the other seat...you said its a good deal and close....good luck
Old 02-25-2018, 05:59 AM
Thanks! Will do. I’ll give feedback.
The Burb Files
Old 02-25-2018, 09:40 AM
Don’t know if they’re different, but we put a bench seat from a ‘68 in our ‘66 Tempest. It was the only one that we could find. It did bolt right in with no problem. The seat itself is wider but that was not an issue.
Old 02-25-2018, 10:14 AM
The guy said his was 55” wide. I’m gonna measure mine on the way.
The Burb Files
Old 02-25-2018, 03:40 PM
Bolts right in.
The Burb Files
Old 02-25-2018, 04:15 PM
that was easy...but that color...I know... you said you would recover it to match. How about some pics of the whole car?
Old 02-25-2018, 05:40 PM
Yeah, I’m going to have my original reupholstered. But I’m going on Hit Rod Power Tour this year, so for speeds sake, I’m gonna dye it. I sit like 4 inches higher!!!
The Burb Files
Old 02-25-2018, 09:10 PM
Is it the seat cushion or the seat tracks? If it's the tracks maybe you can switch them temporarily.
Old 02-25-2018, 11:54 PM
I am surprised - that’s a good bit of trivia to remember.
Old 02-26-2018, 06:55 AM
No my old seats Springs were sprung and had almost zero foam. I did measure the track distances but not the height. I will measure them as well.
The Burb Files
Old 02-28-2018, 08:03 AM
Ill try and take some pix this week. My car is about a 20 footer, so dont expect much. If you have seen Roadkill, your in the correct frame of mind.
That said, dye job looks pretty good!
The Burb Files
Old 02-28-2018, 10:15 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I used early 70s A body buckets in my 64 Impala then swapped them in a 69 Roadrunner! You can make them fit but glad they were a bolt in.
Skip Fix
Old 02-28-2018, 10:28 AM
Old Goat 67's Avatar
My neck hurted!
Old 02-28-2018, 11:24 PM
lol
The Burb Files
