Quick Performance Ford 9" for A-Body
Anyone put this in their car? I am really looking at this hard. Want to replace the 3.23 BOP 10 bolt one legger with this. Really like the Truetrac Posi.
If so what variant do you have and did you have to lengthen/shorten the driveshaft? And how do you like the performance and how was the install? Bolt right in or a lot of massaging, etc? Thanks. https://www.quickperformance.com/9-F...7_p_20385.html
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
I used a Currie Enterprises Ford 9" in my 1967 GTO and didn't have to alter anything. Just rolled out the old one and rolled the new one under. Same driveshaft, same u joints etc.
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and 9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches.. |
Looks awesome!
I have a QP in my car. Very nice. Had to alter backing plates to get stock drums to work and am currently using stock u joints and driveshaft. They are great to deal with. It will come in 3 packages, housing, chunk, and axles that need to be set up.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
I had the spring pads installed but don't use them. Using the QA1 coil over shocks. Wanting to put adjustable coil overs on the front now than can lower the whole car and keep the rake I want..
Ooh sweet got a link for those??
The center section is assembled though right? That’s the only iffy thing I have on a car is preload etc. want this to be easy!!
The center section is completely assembled and ready to go. Just put on sealant, bolt down, slide in axles, put in oil and ready to go..
Finally got the car to the house, YAY!!! Will soon start the rear swap out. Bought both the front and rear QA1 coil overs. Ill take some pics as I go along..thanks for the information, Pokey1.
Was it night and day handling increase??
I did the rears only so far. Have not had a chance to work it hard. Definitely notice a difference in dampening when trying different adjustments on the rear shocks. They wanted me to have 500 miles on the transmission, rearend and clutch before I hammer hard on it. Should have close to that now... Want to do fronts this winter then will hit it hard this year..
I had to order the lower Brackets from Ridetech as the QA1 brackets would not clear the passenger side disc brake caliper.
They should be here this week. Ill snap a few pics of them once I have them installed.
